Positiverake
From what I found the Haas bar feeder is called by g105
but you need to enter the parameters for initial lenght ,
part push lenght, and 1 more ,but i am not at the machine. pram #3001,3002,3003
as for following the stock,the retract pramameter controls this, have tried it, not a good idea with this feeder as it will sag and catch the liner , and you know the noise, may be able to modify the end of the bar to ride on a bearing,
as for the cutting a new bar I always faced every part anyway,
and the bar feeder will push to the same location everytime,if you
make the lead in on the new bars the same, but if you are worried about it pushing it in to far you could write a macro
that counts the parts and only cut face of a new bar, check with the macro gurus here for help
like you I think the bar feeder is a waste of alot of time but it is still better than doing it by hand
Brad
IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
