Alarm message " Parity High " appeared after turning - on the machine . Machine control is FANUC SYSTEM 3T . All function keys are disabled .Help me guys!!!Thanks
only one way....Complete clear...
parameter enable switch on (upper right on main board)
press reset and delete at power on,
you now have to enter all data !
good luck
let's hope he did a backup of all parameters prior to this event otherwise we'll see him here again asking if anyone has a 3T parameter backup
I think so .... but it's too late for thinking !!!
Thank you TMBRUNO28 for your good advice,it was really appreciated but Reset + Delete at power -on also not work instead , i used " P + CAN + DELETE " at power-on . All parameters had been reload machine is OKAY now. Thank's guys !!!
hi i have a Eumach V-24 VMC i need operators manual for it to know which g-codes and m-code it uses with sample programs, if any one have please help me and share
I am having this same issue. If I clear memory, where do I find the parameters to manually put back in? Thanks
I just had the same issue and did the total reset. Reloaded parameters but I'm missing my radius and tool type columns in my tool offset table now. Any help on this? Thanks!
