Hello all. I am relatively new here, and have only ever made one other post.
The problem I am having with the G0602 lathe...When I engage the half-nuts, the bottom nut engages first, before the lever pops into detend position, causing the leadscrew to deflect 25 thousandths upward, and you can hear the bearing groan a bit when it does. Is this normal? Acceptable? Thank you.
Quick bit about me...
I currently own a G0704 mill which I just finished converting to CNC...very capable mahcine... and very fun to operate. Thanks to Hoss and everyone else who posts...could not have done it without all of the prior knowledge on this forum. I also I have an Enco (Rf-31), as well as the G0602 lathe. I will post more info about myslef and the machines with (hopefully) a few photos tomorrow. I just wanted to get the question out before I go to sleep.
Again, thank you
Don
