I wanna show my solution for the water spindle, it's working so good.
http://youtu.be/Qy_ja34B8ng
At 35 degrees the fans and LED's switch on, at 33.9 off.
I couldn't find so many information about this so I wanna share my solution.
Juan
Juan
Juan,
Your solution is not only great looking it also looks to perform as designed.
Can you share build directions and sources of supply, schematics etc.
I have a Syil X5 Speedmaster, with a 24K watercooled spindle, I just acquired and need to replace the spindle shiller pump. I dont like the current setup and would like to make an alternate solution independent of the Syil control.
Any info would be appreciated.
Mattster1
I'm using the XSPC Rasa 750 kit, I bought it here:
XSPC Rasa 750 RS360 Universal CPU / Triple Radiator Water Cooling Kit w/ Free Kill Coil! (ETA - mid-June) - FrozenCPU.com
The liquid is the non conductive Feser One:
Feser One Non Conductive Cooling Fluid - 1000 ml - UV Pink (F1-0007) - FrozenCPU.com
The temperature controller is this:
http://www.ebay.es/itm/Automatic-Dig...item6b1e926426
I bought a few accesories to connect the tubes, a T to put the sensor touching the returning water and a metal box for the temperature controller.
I bought this too to connect a tube with similar diameter of the spindle barbs
Koolance 1/4" (6mm) ID G1/4 Threaded Barb w/ Hose Clamp - Single - Black (NZL-V06B-BK) - FrozenCPU.com
With one liter of liquid is enough but if the circuit is long, buy 2 liters, just in case.
Juan
Juan,
How is this system holding up for you? Also, could you share where you purchased the box for the temp controller and how you are powering the fans, pump and temp controller?
Thanks Dave
My system is working like a charm.
I bought the box in a small shop in Akihabara, Tokyo. Now I'm living here.
To power the system I'm using a 12v power supply that I bought in ebay.
