586,121 active members*
3,637 visitors online*
Page 1 of 2 12
Results 1 to 20 of 31
    Dec 2011
    81
    New Build Questions
    I need a 4x4 or 4x6 sized plasma cutting water table system and over the last week have found most of the answers to my question here at cnczone. Now I have some questions that only experience can answer and I know that different choices can be made to satisfy performance or cost. I'm making decisions based on cost. I have recently built a stepper motor driven 3D printer and understand the basics. I hope this is where I can ask questions and document my progress to getting a cutting table working and save a fair bit of money building a table on my own.
    It seems I need to settle on a number of choices:
    1. What hardware drives the table- motors and controllers?
    2. What type of linear rails and glides or rollers will I use?
    3. Do I need a 4 th axis for torch lift... why do some cnc cutting tables use 2 motors- 1 for thicker stock and another for thc?
    4. I use Linux for everything and is EMC2 trouble free for plasma cutting?
    My current Jeep build is on hold until I get my table up and running, so I'm motivated!
    Thanks for any ideas and advice.
    Feb 2006
    1260
    Quote Originally Posted by jeepsterjc View Post
    One of the simplest choices for hardware for a really nice matched up system with great support is www.candcnc.com For small to mid size machines look for the dragon cut series.
    This is certainly not the cheapest but most likely the most complete & simple hook up out there. Not all that expensive either when you really take time to compair apples to apples when piecing a system together.
    I like "V" rail on plasma simply because it tolerates a dirty environment better than most any other.
    If you use a dual motor drive for your gantry you will need a 4 axis drive system
    If it works.....Don't fix it!
    Dec 2011
    81
    Quote Originally Posted by millman52 View Post
    Thanks, Neil. I wired my smaller Z axis nema steppers on the 3D printer in parrallel. So that's where the 4th axis is then. Dumb question next- Why do some plasma tables have two motors for torch vertical movement then?
    Do builders have a favorite place for buying "V" rail?
    Why do builders buy candcnc hardware over a torchmate system?
    Jan 2011
    I don't think anyone has two motors for the Z axis--what you might be seeing is one motor for the Z, and one for the X, to move the Z axis/torch holder across the gantry.
    One reason I chose CandCNC is price--it includes a lot of functionality built-in that is extra with other systems. Example--I got all my electronics, motors, wires, AND the built-in torch height control, for about $1500. Torchmate for example (since you mentioned them) charges $2500 for JUST the torch height control, and that's AFTER you've already bought all the other stuff from them. (not that there's anything wrong with Torchmate--they just accomplish what they do in a different way than CandCNC)
    Carl
    Dec 2011
    81
    Quote Originally Posted by I Lean View Post
    OK. I must have been confused by the motor arrangement. I didn't know that TM's thc cost so much extra. That little extra charge of $2500 knock them out of my range.
    Jim
    Dec 2011
    81
    Geared vs Direct, Geared Z, Motor Size ??
    I'm looking at ShopDroid's packages and am almost ready to make the order. It sure is a less expensive way to go rather than buying a completed gantry off of ebay for $3000 to $5000.
    I need to figure out if the gear-reduction is worth it for me. I'd like the table to be reliable and accurate and still inexpensive... I'm thinking that for the extra couple hundred I'd be willing to go gear-reduction on X and Y.
    Is gear-reduction on Z necessary?
    All of the bracket kits come in at around $600 and would really speed up the build for the 4x8 table.
    So back to the CandCNC.com option. Does buying the candcnc $1450 4 axis system with the larger 620 oz motors make sense? Why would I go with the stronger motors. Will the table last longer or improve precision?
    Thanks everyone for your opinions and sharing your experiences. Jim
    Dec 2011
    81
    Gantry brackets ordered
    I spoke with John at NoSleep Studio and purchased:
    1 x ULTIMATE DIY PlasmaBot 3.0 Gantry Kit
    1 x ShopDroids Z Axis Drive
    1 x Z Drive Floating Torch Plate Kit
    Now I need to sort out the electronics.
    I can buy for what seems a low cost something like http://www.kelinginc.net/CNCNEMA23G540Pac
    kage.html
    using 381 oz motors then add THC to it with an aluminum housing and other wiring and connectors. The cost comes to maybe $800 to $900.
    Or, I can buy the BladeRunner Dragon Cut System 620-4 for $1478.00. The Candcna.com BladeRunner uses 620 oz motors and may leave me with future expansion... By the time I increase the size of motors using a more DIY plan the cost even narrows more. I'm thinking maybe buying the BladeRunner Dragon Cut 620 system may not be a bad idea.
    What do you guys think? Is there anything wrong with the BladeRunner Dragon Cut System that your are unhappy about? ... failing/customer support/quality ... ?
    Mar 2009
    924
    Support and Solutions
    If support is important to you, then I would go with CandCnc's stuff. I have a few years CNC plasma experience and have found proper support to be worth double what the purchase price is. If you run into a problem, then a expedient solution compounds it yet again. I just recently installed a PlazPak servo system from CandCnc and could not have done the "get up and running" in the time frame it all happened in without the expert help received from the crew there. The CandCnc support forum has some good answers and some really experienced users there willing to help you too.
    My two cents
    WSS
    www.metaltechus.com
    Dec 2011
    81
    Quote Originally Posted by WSS View Post
    My two cents
    WSS
    That's what we decided to do- go with the CandCnc Bladerunner 620-4 system. By the time I had added all of the small stuff into a 4 620 oz motor system with thc, powwer supply, enclosure and cabling the cost was close. And for the extra amount I know I'll have a well supported electronics package.
    Jan 2011
    That's the route I went also--I couldn't be happier, and 100% recommend CandCNC to anyone trying to decide. I was new to the CNC world when I built my table, so the help I got from Tom was not just valuable, it was NEEDED.
    Carl
    Dec 2011
    81
    Smile
    My two cents
    WSS
    Thanks for your thoughts on the way to go for electronics. It helped a lot.
    Dec 2011
    81
    Good advice, Carl. i appreciate it.
    Dec 2011
    81
    Water depth for water table design
    I'm drawing up my plasma water table in Pro/E and don't know what a good water depth would be. I'm looking at a 50 inch cutting width and a 52 inch wide table- edge to edge for the water table/slats. I can do this with a 5 foot wide sheet if I make the sides 4 inches tall. Is this deep enough?
    Thanks.
    Dec 2011
    81
    This is what I have so far. The ShopDroid Z allows for large vertical (that will be handy when I switch the Z over to 3D printing) I have 10 inches from the top of the water table to the bottom edge of the Z torch holder assembly.
    So now I need to draw up a minimal support structure for underneath the water table basin and just wait for the parts to start arriving.
    Aug 2008
    303
    Thanks.
    I made my table the same way !!
    I used a 5 foot by 5 foot piece of .125 aluminum. One end is 4 inches deep, and the other 3 inches. I did this so that it would drain completely. It works absolutely perfect !! It fills in 1.5 minutes, and drains in 45 seconds.
    I keep the water level 1/4 below the top of the slats, and I like the results. Some will say to keep the water further away from your metal, but then you will have way more crap in the air, which is the reason you want a water table in the first place.
    BTW, where in Canada are you?
    Dan
    The one that dies with the most tools, WINS !!
    www.dantechfabricating.com
    Dec 2011
    81
    Quote Originally Posted by Danno View Post
    Dan
    Hi Dan. I'm in south BC, where Kokanee Beer comes from. Big Sky Brewing, in Montana, is way better.
    Why is draining the table so important? I haven't built any slope into it, yet...
    How deep do you usually fill it?
    Thanks, Jim
    Dec 2011
    81
    I've also purchased ShopDroid's Geared Reduction for 3 axis. I figured I may as well try to build the best performing plasma table that I could afford because a noob like me needs all of the advantage he can get!
    Aug 2008
    303
    Thanks, Jim
    Well you're too damn far to come over and see my table !!
    I'm in Ontario !!
    I don't want to leave my table filled for a couple of reasons. The main one is evaporation. I also don't want the flies to make my table their private lake.
    If you're cutting lots of pieces, it's nice to be able to drain the table so you don't have to "fish" out all the pieces.
    And lastly, is to clean the bottom of the pan.
    Like I said in my lasy post, I fill it 1/4 inch below the top of my slats.
    Dan
    Dec 2011
    81
    How to avoid torch head jambs
    I've been asked how I can avoid having my torch head jamb up against an up-turned piece of metal. One that teeters over then stops before falling between the slats...
    I had been wondering that myself and thought that taking care and monitoring the cut job was the answer. Are there any other tricks or mechanisms that I could use/build to avoid damaging a torch head, gantry, or expensive cut job?
    Aug 2008
    303
    My torch head is held on by 4 magnets, and 2 locating pins. If it jams up, it just falls off
Page 1 of 2 12
  1. New Build Questions
    By Imacman in forum Open Source CNC Machine Designs
    Last Post: 02-04-2012, 02:49 AM
  2. Pre-build how-to questions
    By Mountaincraft in forum MetalWork Discussion
    Last Post: 01-27-2011, 04:57 AM
  3. New Build questions
    By joebass in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-01-2011, 12:14 AM
  4. New Build Questions
    By PCFlyer in forum CNC Wood Router Project Log
    Last Post: 11-16-2010, 09:14 PM
  5. Questions about a new build
    By bandtank in forum Joes CNC Model 2006
    Last Post: 10-24-2009, 03:31 AM
