Hello
I can't get the program from the PC to the CNC (fanuc OT model B).
The way i trying to do it is the following:
1. edit mode
2. prgrm button
3. key in address O
4. key in program number
5. hit input
LSK starts flashing
6. start sending from the pc
The Pc says that the program has been sent successfully, but LSK is still flashing and nothing happens.
Shouldn't the LSK stop flashing when the CNC has read the first %-sign
If I try to registering a program to memory using MDI key.
1. edit mode
2. prgrm button
3. key in address O
5. hit insert key
Doesn't work, nothing happens!
If a try to delete an existing program, that doesn't work either.
1. edit mode
2. prgrm button
3. key in address O
5. hit Delete key
Does not work, nothing happens!
Its almost like there exist an extra program protection parameter apart from the program protection key.
I have no problem getting program out of the CNC.
I have also tried to upload programs I have downloaded from the CNC but without any luck.
The program and setting I use DNC software. CNC and DNC settings for Fanuc 0T.
The program I'm trying to upload http://ajden.se/O0600.nc
