587,333 active members*
3,008 visitors online*
Hybrid View
    24223
    Hydraulic danger
    Caterpillar Tunneling Canada Corp., a Toronto-based company that designs and builds tunnel boring machines (TBMs) used to dig underground circular tunnels, was fined $130,000 on Dec. 22, 2011, for violating the Occupational Health and Safety Act after a worker was injured.
    On Sept. 15, 2010, the TBM involved in the incident had been hydraulically pressurized to ensure its components and functions were working properly. The TBM contained a safety device called an accumulator, which remains pressurized even when the rest of the machine is not pressurized or otherwise operational. The accumulator must be depressurized separately prior to its disassembly. That afternoon, the company failed to confirm that the accumulator had been depressurized, as that person responsible for this task had been directed to help with other work.
    Later in the evening, a worker was directed by a supervisor to help two other workers to disassemble and prepare the TBM for shipment. When the crew unscrewed a hydraulic hose that was connected to the accumulator, a jet of hydraulic oil hit the worker in the face and neck. The worker then fell and suffered head injuries.
    A Ministry of Labour investigation found that Caterpillar Tunneling Canada, as an employer, failed to ensure the pressure inside the gas compartment of the accumulator was adjusted to atmospheric pressure before a hydraulic fitting was removed.
    Caterpillar Tunneling Canada was fined $130,000 by Justice of the Peace D. Keith Currie. In addition to the fine, the court imposed a 25-per-cent victim fine surcharge, as required by the Provincial Offences Act. The surcharge is credited to a special provincial government fund to assist victims of crime.
    Ontario Ministry of Labour
    Albert E.
    Apr 2005
    175
    Accident
    "Trust is good, control is better" As a mechanic, I would have verified that the system was not under pressure, before working on, just as an electrician would check that the circuit is not live ( or could become live) and not just taken the word of a supervisor. Courts can put a monetary value onto an accident, but this does not compensate the victim if he/she is dead.
  1. Need help in hydraulic oil
    By keyancnc in forum Maintenance DIY Discussion
    Last Post: 01-26-2012, 06:50 AM
  2. Danger: Exploding Capacitors
    By Eurisko in forum Stepper Motors / Drives
    Last Post: 03-02-2008, 05:48 AM
  3. Tiredness Danger
    By ImanCarrot in forum Safety Zone
    Last Post: 02-10-2007, 11:18 PM
  4. induced voltage danger?
    By Oaktreeman in forum Community Club House
    Last Post: 05-25-2006, 05:12 AM
  5. Danger Tunes: Your Emails
    By WallCrawler in forum Community Club House
    Last Post: 04-15-2004, 05:03 PM
