586,116 active members*
3,322 visitors online*
Results 1 to 7 of 7
    Jan 2012
    17
    Help, need to replace this timing belt
    Hello, I need to replace this belt. I do not know where to order one.
    Can anyone help me?
    Here is a picture of the belt itself and the parameters (see photo).
    24221
    Albert E.
    Jan 2012
    17
    While I was looking in google I had found that site and the belt I think I need:
    A 6R19M42506 6.35mm Wide By 425mm Long, Flat belt
    https://sdp-si.com/eStore/PartDetail...13&GroupID=348
    But I'm from Europe, Lithuania. I have a Mastercard and for some reason it will not work in their e-store cart system. I also have Paypal.
    The SPI replied that they can charge my credit card manually but that adds +10$ for this and that is more then the belt actually costs. And I don't even know if it will work for me. They can't quote shipping until :
    "SDP-SI does not quote freight charges. Freight is determined by the listed rates of the carrier you choose to ship with. Size, weight, location, duties, taxes and customs can affect the price which cannot be known until order is placed, packaged and measured."
    Also what does this mean they said about shipping?
    "Incoterms - FOB NHP New York"
    My pulley diameter is 4.5 and the belt has diameter specified as Min.pulley Dia. 6 so perhaps it will not bend at that small diameter? I need that core material would by like Fiberglass reinforcement.
    24221
    Not sure if it will help, but Misumi world wide show a distribution next door in Poland.
    They have quite a selection.
    Al.
    Albert E.
    Jan 2012
    17
    Al.
    Can you share the link to what belts they have? I can find only this site
    Misumi world wide MISUMI Worldwide | MISUMI Group Inc.
    24221
    I haven't checked exactly what they have, but this is a flat belt link to them.
    Flat Belts | Mechanical Components for Assembly Automation - Misumi eCatalog
    Al.
    Albert E.
    Jan 2012
    17
    Al.
    They do not have 6mm or 6.5mm or 6.32mm or 6.35mm belts at all.
    All I found was 5mm then there is 10 and more wide belts.
    What if i would use timing belt (neoprene) reversed with the teeth outside would it work?
    I also have some printer timing belt that would work if reversed very soft and good traction, but length does not match. It is yellow translucent perhaps you know the type? The teeth go at a slight angle too.
  1. can't get x3 belt on?
    By Teyber12 in forum Benchtop Machines
    Last Post: 08-09-2008, 05:43 PM
  2. X3 Belt - Where to buy
    By dneisler in forum Benchtop Machines
    Last Post: 06-08-2008, 10:27 PM
  3. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
  4. Belt size/spec for Sieg X3 driving belt
    By rashid11 in forum X3/SX3/G0619/G0463
    Last Post: 02-10-2007, 02:01 PM
  5. Seeking Belt Sander Belt Source 6 x 48
    By Dugg in forum Uncategorised MetalWorking Machines
    Last Post: 12-24-2006, 04:48 PM
