Hello, all -
I'm working on the re-wiring of my milling machine, and I've run into a question about power for the SD1525 servo controllers.
They're mounted in an open chassis with three controllers for X/Y/Z and one free slot. The chassis appears to have a power supply section integrated with it that includes four individual rectifying diodes and a capacitor.
My question, or maybe assertion, is this: It looks like I just need to supply an AC voltage capable of being rectified to within the allowed DC spec of the cards to the motor power supply terminals on the chassis in order to power the servos. Is this the case? I'm not talking about the card supply. I will be supplying the cards with 110v AC for their own power via a GFCI.
The original electronics were set up to supply the chassis with 83 volts AC, which if I'm correct about the power supply section in the SD chassis will get rectified into about 125 volts, which is the rated DC for the motor.
According to what I've read on these cards, they can accept a wide range of DC voltage input (in this case supplied by the rectifier section of their own chassis) depending on the desired voltage for the servo motors.
Can anyone with experience with this Servo Dynamics chassis (used in Lagunmatic, Tree, and other mills) verify this?
I want to be sure I can just hook up 83 volts to the chassis input (it was this way before) and have the chassis supply valid DC power to the cards.
I also want to know if I need to replace the servos with a higher voltage model if I can just up the AC current to the chassis (within the range of allowed spec of the ripple cap, of course) and get a higher DC voltage range sent to the servos.
I'm thinking this is the case because these cards were designed to work with a large variety of servo motors, but I want confirmation before I blow something up
Erik
