586,042 active members*
3,717 visitors online*
Results 1 to 11 of 11
    Dec 2010
    313
    Exclamation CNC Lathe Construction question
    I posted earlier look for a solution to a chuck, it isn't quite solved yet but thats alright. I am now on a different problem/ question.
    I have this contactor what is a cnc contactor and I am wondering how I use it to control the spindal motor. I am using steppers to move the tail stock and the tooling. The spindal is a DC motor out of a blower and it would be very cool if I could use this contactor some how to control the motor.
    Is it something I can use with pokeys or phidgets?
    Thanks for any help.
    Rob from what is a cnc
    My contactor is found at what is a cnc contactor and there is a link on the page to one for sale on the page.
    24221
    The contactor you show is primarily used for 3ph AC control, DC requires some special arc shields and contacts, normally you control the spindle motor through a controller of some kind? or are you operating this motor full on?
    Do you need reversing feature?
    Al.
    Albert E.
    Mar 2011
    584
    I use a contactor (same brand) in my powder coating oven 220v 1phase and its really loud! I think you would burn it out trying to control a motor or drive you nuts before it burned out. At minimum get a SSR with a heat sink.
    Maybe use that in conjunction with the Super PID and have it trigger the SSR...
    keep the contactor to be your main power switch to the machine
    24221
    Quote Originally Posted by vtx1029 View Post
    The OP mentions a DC spindle, the PID is for a universal motor.
    It all depends on the nature of the spindle control?
    Al.
    Albert E.
    Mar 2011
    584
    Al.
    oops I miss that.
    Dec 2010
    313
    Thanks for all your help.
    I suppose I am better off just leaving things the way they are for now, I don't need to control the spindal and if I do I will just change the motor to a stepper.
    I just figured I could use the contact block for something, it has been sitting around for a while now.
    Al what do you mean by a "universal motor"?
    24221
    Quote Originally Posted by crob09 View Post
    A search will show several hits, Universal motor, field in series with the armature, will run on ac/dc, rpm limited by friction.
    Most hand tools, vacuum cleaners, routers.
    Al.
    Albert E.
    Dec 2010
    313
    Talking
    Thanks!
    So there is a chance this is a Universal motor, it came out of a blower. We used it in a playground "Ballocity" unit until a child threw a rock in it and destroyed the fan.
    I will upload a few pictures to the forum along with any numbers found on the motor when I get home and settled tonight.
    Again thanks for your help and time, your a very knowledgable person!
    Dec 2010
    313
    Smile
    Also I may need to buy you a beer later tonight! I just noticed the option and you deserve it.
    24221
    Thanks!
    Very possible, I assume you thought it DC because of the brushes Maybe?
    Thanks.
    Al.
    Albert E.
    Dec 2010
    313
    Yes the stator is a magnet and the armature is magnetized threw the brushed. I also figured the capacitor attached acts as a rectifier.
    Now on to buying you that beer!
  1. Construction of Steelie
    By timber_MG in forum CNC Wood Router Project Log
    Last Post: 12-18-2011, 07:45 AM
  2. Question about gantry construction
    By nokode in forum DIY CNC Router Table Machines
    Last Post: 08-07-2011, 05:09 PM
  3. help in construction!
    By drumbuilder in forum Wood Lathes / Mills
    Last Post: 01-28-2008, 02:43 PM
  4. 80/20 Specs - Lathe Construction
    By Deviant in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 04-06-2005, 04:27 AM
  5. Construction update!
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 02-05-2004, 06:06 AM
