586,036 active members*
3,695 visitors online*
    Oct 2011
    leaking oil dont know why!!
    hello there all
    i am running a amada pega 357 and i have a leak in the back part of my clutch system. (i think its the clutch) but im not sure one how to stop it, in the pictuer you can see the hose going into the metal block then that block into what i believe is the clutch system. and that is where its leaking from, i check my hydrolic oil every morning and at end of shift, but it seems like it aint losing any. has there been someone out there with this problem before? and if so is it an easy fix?? hopfully just an o-ring or something like that, but we tried to fix it before and changed o-rings and it still leaked. any comments????
    Apr 2008
    17
    There are two places that these commonly leak. There is a swivel assembly that mounts on the end of the crankshaft that is prone to leaking. The only real fix is to replace it. There is an oil seal that seals around the crankshaft. It would be a good idea to check if the end of the crank moves up and down when it punches a high tonnage hole. If the crankshaft bushings in the frame are worn and the shaft moves then the seals will leak even if brand new.
    Hope this helps.
    Jul 2021
    Re: leaking oil dont know why!!
    Hi I am Saunit from Cambodia, do you have some pictures or videos of replacing parts?
    thank you,
    Jul 2021
    Hi I am Saunit from Cambodia, have you fix the troubleshooting? do you have some pictures or videos of replacing parts?
    thank you,
  1. Coolant Tank Leaking
    By mekp21 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-15-2010, 06:05 PM
  2. FJV-250 Splindle leaking oil!
    By Hastx in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-29-2010, 07:44 PM
  3. SL-10 leaking like an old dog?
    By shawncnelson in forum Haas Lathes
    Last Post: 11-05-2008, 09:42 PM
  4. Haas TM2 Leaking Coolant
    By Chris Swier in forum Haas Mills
    Last Post: 06-21-2008, 03:57 AM
  5. thru spindle coolant leaking
    By GARY DAVIS in forum Fadal
    Last Post: 03-25-2008, 01:28 PM
