586,069 active members*
3,946 visitors online*
Page 1 of 2 12
Results 1 to 20 of 39
    Jan 2012
    789
    Need to hold a 1" ball nose
    First post here, looks like an active forum!
    I've tried my best searching for an answer to this question. If it's already been answered many times, I apologize.
    I have a new part that needs to use a 1" ball nose end mill. Not major cutting, just need the curve. However, I can't figure out how to hold the mill! All the ones I find online are either 1" or .75" shank. The biggest bit a TTS will hold is a 1/2".
    Just cutting 6061.
    Surely this problem has occurred many times and there is a easy solution I'm missing?
    I am unsure how to go about cutting my own TTS blank, not sure how to get it precise enough?
    Thanks for any help!
    Tom
    Feb 2006
    1072
    The TTS R8 collet is .75", Tom. I have held a loooong flute .750" endmill in it for initial machining. Of course, once I progressed to the rest of the tools I had to touch down the first TTS tool to re-establish Z. Even if your part is fully contoured with the 1" ball-end, you should be able to find a surface (vise jaw, tooling plate, etc.) to touch down the first tool for a reference Z once you're done with it. Just a thought.
    Randy
    Dec 2010
    66
    Buy the tool with 3/4 shank and "TTS it". The best way is to buy a 3/4 shaft collar from McMaster-Carr then machine out the TTS recess from the collar and just clamp it on. That scheme was described here before -- it works great.
    Apr 2011
    720
    Hi Tom,
    Welcome to the forum, hope you find it interesting and fun!
    Is there a reason you must put your cutter in a TTS holder? Couldn't you get the one with a .75" shank and place it directly in the R8 collet in you mill?
    Terry
    Jan 2012
    789
    Ok, that's kinda embarasing. Yes, that seems like it could work very nicely. What about putting the TTS collar that tormach sells on it? That or the shaft collar should do the job. I only need about 5-10 thou repeatability on this pass, so a collar should do the job.
    Thanks for the quick and intelligent responses!
    Jun 2006
    2512
    Here's a low cost alternative:
    R8 End Mill Holders (WT)
    The added anvantage is no risk of pull-out.
    Phil
    Aug 2009
    986
    Quote Originally Posted by tbaker2500 View Post
    You'll find that there's a lot of that sort of thing on this forum.
    Frederic
    Jan 2012
    789
    Quote Originally Posted by philbur View Post
    Phil
    I've never used a R8 holder, my understanding is that I have to remove the TTS collar? So I couldn't use the TTS and the R8 tool holder without reconfiguring the machine? That's a downer if that's the case, since I have about 6 tool changes on this part. :-(
    Thanks!
    Jul 2007
    1602
    See this post http://www.cnczone.com/forums/858065-post12.html for one way to add a tts collar to a 3/4" shank end mill.
    bob
    Jan 2012
    789
    I got the bit in today, and I'm thinking that I might be able to mount a TTS conversion ring onto a shaft collar. I'll give it a try, and I'll post my results.
    Jan 2007
    1332
    Here are some pictures of my TTS conversion of a ¾” shaft tool:
    Don
    Jan 2012
    789
    Thanks Don!
    I don't have a lathe, although I could do it on the tormach I suppose.
    Does the TTS flange have to be perfectly centered? I'm wondering is I could take a hefty shaft collar, and a TTS flange. Drill/tap and screw the flange to the collar, then I would have a 3/4" TTS adapter which could be moved between tools. ( I'm using an end mill, not indexed, so I will have to change bits every so often. )
    Oct 2011
    121
    The shaft collar needs a stop on the lower side so that when you the tighten the drawbar, the collar doesn't get pushed downwards slightly.
    Jan 2007
    1332
    Thanks Don!
    The shaft does not have to be perfectly centered however the collar must be square to the shaft as much as possible. After using anaerobic Loctite 271 (red) adhesive to glue the collar in place I put the TTS assembly in a 3/4" 5C collet on my lathe with a small amount of inside collar exposed and faced the collar square with a thin lathe bit, Nickole grooving tool, or a Do-Grip cutoff tool. One could do this in place on the Tormach instead of on the lathe with probably better results. Remember that TTS has dual contact and with the spindle face and collet so the surfaces must be square to get an accurate tool with low runnout.
    Don
    Jan 2007
    1332
    Quote Originally Posted by beanbag View Post
    There was no diameter increase for a stop on the 3/4" diameter Vardex thread milling tool so I cut a 0.043” width 0.704” diameter groove for the ¾” 0.042" thick external retaining ring shown. In fact the 3/4" diameter shaft decreases diameter on the portion below the added TTS collar. I used a Nikcole Mini-systems grooving tool with carbide insert GIE-7-SG-1.1 on my lathe with the Shaft held in a 3/4" 5C collet to cut the groove. The groove could also be cut in place on the Tormach with the shaft held in the 3/4" R8 collet used for holding TTS tools.
    Don
    Feb 2008
    154
    Smithy also sells a TTS holder that takes 3/4 shanks. They are cheap too, like $15. I have a couple from them (not the 3/4 though) and they are fine.
    Christian
    Jan 2012
    789
    Quote Originally Posted by concombrefrais View Post
    Christian
    I looked, but couldn't find it. Do you have a link?
    Tom
    Jan 2007
    1332
    Christian
    TTS uses a 3/4" diameter collet. Why would one put a 3/4" shaft tool put in a TTS adapter that fits into a 3/4" collet? Why not use the 3/4" tool directly into the 3/4" collet with a TTS collar? BUMP
    Don
    Jan 2012
    789
    Well, I'm working on what an earlier poster suggested, using a collar on mounted onto the tool itself to try and achieve repeatability. No holder as per se.
    Feb 2008
    154
    Tom
    You can click here Milling | smithy.com and then click on tool holder set, it will open a window where you can chose a holder separately.
    Don, I do not know the answer to your question. May be for the convenience to replace one tool to another.
    Christian
Page 1 of 2 12
