586,058 active members*
3,415 visitors online*
IndustryArena Forum > CAM Software > CamBam > Another newbie badly in need of help
Results 1 to 7 of 7
    Jun 2011
    10
    Hi to the great CNC community.
    Firstly, please forgive me if I am posting in the wrong forum. I have a few questions and do not know if I should post in individual forums.
    I'm from South Africa and have been interested in computer controlled devices for quite a few years now. Unfortunately, parts , especially the electrical side is not readily available here, and what we can get is expensive.
    I am planning to start my first build soon. I'ts a wood router from a book by Patrick Hood-Daniel. Would this be a reasonable build for a beginner on limited budget? I know it could do with a few improvements but that can be done later. I already have the CNC kit which I imported from China.
    I already have EMC2 installed on a dedicated computer for that.
    I have purchased Cambam and have the evaluation copy of Cutviewer Mill. I've spent the greater part of the last two weeks playing around, trying to learn the program, and that is where my real question comes in.
    If I have a drawing (2D) that I want to cut out, the cut is not made through the material. I define my stock size and thickness in the machining properties, but when I run Cutviewer Mill it says something about no stock defined and brings up a dialog box where I can define the stock size. In this box the X and Y sizes are correct as but the thickness is greater than I defined. The Z origin is also showed the same as stock thickness.
    I have read through the manual several times and tried playing with settings but to no avail.
    I also noticed that on the backplot that it cuts air before cutting the stock. How does the machine determine how far it is from the stock. I'm not sure what I an doing wrong or if there is just something I misunderstand.
    I'd appreciate any help I can get.
    I don't use CamBam or Cutviewer, but I believe that CamBam need to add a line to the g-code file so that cutviewer knows the stock size. I think it should look something like this, that I copied from some code generated with MeshCAM.
    (STOCK/BLOCK, 6.000, 12.000, 0.750, -0.000, -0.000, 0.750)
    Asking on the CamBam forum would probably be your best bet.
    Jun 2011
    10
    Thanks Gerry,
    I do not see a line similar to that in my G-code. I will try to add one manually, but will also try the Canbam forum.
    Alan.
    Nov 2006
    40
    Alan,
    I'm really unsure on this, but when you select the "post processor" under the "machining tab" did you select the Mach3-CV option? The CV stands for Cut Viewer and I thought it might add the correct entries for stock size? Just a thought, I don't use CV so I hope I'm not leading you on a wild goose chase/
    Ron E.
    Nov 2006
    40
    I'm sorry, I need to go to bed, I just noticed you're using EMC2 so ignore my last post.
    Ron E.
    Feb 2012
    5
    Welcome to this great hobby. I am a source of amazement to all my friends with the fantastic items I produce.
    For the novice, the book machine is a good place to start. Many of us are experienced woodworkers or engineers and just have to take it to the next level right away. But as Patrick will tell you, build the first machine, then use it to cut really great parts for your second machine if you are not a good woodworker.
    When I build my machine, other than the electronics, anything I could not get at the hardware store I purchased off of ebay. It takes a bit of work, but you can find everything.
    In CamBam, in the drawing tab there are two trees, layers and machining. Click once on Machining. The first selection on the displayed properties below is Stock. Click on the plus sign and enter your measurements.
    Feb 2009
    95
    Don't know how things are with EMC2 but for Mach3 there is a separate post processor (Mach3 CV) for cut viewer to work correctly. I don't have CV and rely only on what CB itself displays.
  1. Need AXYZ parts badly!!
    By fgwilson99 in forum DNC Problems and Solutions
    Last Post: 02-24-2011, 08:18 PM
  2. NEED HELP BADLY
    By salvador781 in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2010, 12:23 AM
  3. I can blame this on Bush too if it goes badly!
    By donnydanger in forum Commercial CNC Wood Routers
    Last Post: 11-30-2008, 08:36 AM
  4. Need help badly Auto tool Zero
    By native34 in forum CNC Machine Related Electronics
    Last Post: 09-22-2008, 10:56 PM
  5. Z Axis problem Need help Badly Please anybody
    By rodzilla in forum Benchtop Machines
    Last Post: 09-02-2007, 08:06 PM
