If you want to hook it up with the speed control bypassed follow the black into the switch out of the switch to the field the other side of the field will be to the armature brush out of the other brush to the other side field, out of the field to the other power input, follow the red line to the white the speed control is snipped out shown by the red slashes.
The white at the top is removed or cut.
Al.
Albert E.
