I saw a certain CNC milling machine that seemed pretty well engineered, except for one feature... they appeared to be using one truck per rail, and two rails total for the Z axis. The compromise made here seems to be to reduce cost (2 less trucks) and to squeeze out a bit more Z axis travel at the expense of some rigidity. My question then is, how good are say, THK SHS blocks in a twisting load that goes front to back, orthogonal to the axis of the rail and the axis pointing down through the rail? Is this a smart way to design a machine?
