586,052 active members*
4,253 visitors online*
Results 1 to 9 of 9
    Nov 2011
    More dual axis homing issues
    Hi Everyone,
    I have just finished retrofitting my multicam router (big sucker 70"x140") rack and pinion.
    Obviously at that size it's dual drive. It has prox switches on both drives to square the gantry when homing. I have everything hooked up via my C32 and my ethernet smooth stepper.
    I have my A Axis slaved to X and I have the the direction pin active hi on the A axis and low on everything else. I have the homes set as negative and all the axis normal (ie not reversed). All motors are wired the same. Everything jogs great and the Z and Y axis home just fine BUT.... The XA / XB is a mess.
    Here's what happens. Whatever axis hits first does its little bounce off the home switch just fine, the other axis (usually the A) might jump around a little, might not do anything, but it will not move off the axis and the home sensor will remain active on that axis.
    If I look at the prox switch locations they are inconsistent, the second switch which hits will always be more "over" the dog where as the first axis will move off the dog so that they are not inline.
    What's going on??? I need to get my machine back up and running so I'm desperate.
    Thanks!
    -Ed
    Jan 2009
    72
    I am thinking on buying the ESS. The only thing stopping me is the duel axis homing issue.
    Is this issue across the board for all users of slaved axis or just for some users?
    Any one have a setup that works?
    I use a G540
    Cheers
    Jan 2007
    325
    I just installed a ESS in an ongoing build. The homing appears to be working but I had to load the latest MACH3 and use the latest plugin.
    It does seem like a solid board.
    However, it doesn't look like the 'Verify' button is working but I haven't looked into it at all yet.
    BobL.
    Mar 2009
    533
    I too am interested in this issue. I have the ESS but not yet installed.
    I hadn't thought about homing the slaved A-axis separate from its master axis, also X-axis in my case.
    I don't know how you guys wired the homing switches, but I suspect that Mach3 will need to identify each homing axis separately. I currently don't see it as an ESS issue.
    Jan 2007
    325
    It definately appears to have been an ESS issue, but I think it has been fixed in the latest plugin release.
    I was surprised how smooth the install went.
    BobL.
    Mar 2009
    533
    Thanks, that's good to know.
    Jan 2009
    72
    Thanks for the feedback.
    Seems the homing issue is getting/been sorted.
    :cheers:
    Jul 2008
    340
    I slaved homing working yet?
    I just bought an ESS for use with a PMDX-126 on a CRP-4848. I'm definitely running into the slaved homing issue since the CRP-4848 has a slaved X-A.
    I have limit/home switches on both the X and A. An the problem shows its self when I enable the A-Home. If disabled homing works, but the a is typically out of square.
    I've also seen pretty violent response from my system when I do home or if I hit Reset in Mach3 twice in a row. I suspect this is the ESS being out of sync or getting garbage for commands. The table moment is abrupt enough to make me worry about twisting the gantry and binding the table.
    -Freeman
    Oct 2013
    14
  1. Dual Y Axis Slave A Axis Homing Problems
    By guy2b1 in forum Calibration / Measurement
    Last Post: 03-03-2012, 11:06 PM
  2. EZ Trak homing issues
    By Fusioncraft in forum Bridgeport / Hardinge Mills
    Last Post: 12-05-2011, 02:20 PM
  3. Dual Steppers or Timing Belt for Dual X-axis?
    By GEBrown in forum Linear and Rotary Motion
    Last Post: 05-27-2010, 05:45 PM
  4. Help please? Homing issues!
    By D.L in forum Mach Mill
    Last Post: 03-02-2009, 05:32 AM
  5. Dual Z axis and Dual Spindle
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 08-28-2008, 09:15 PM
