586,406 active members*
2,814 visitors online*
Results 1 to 16 of 16
    Jan 2012
    25
    Quote Needed for small parts 2,000 pieces
    Hello CNCZone
    I am in need of a quote for 1,000 of each piece.
    The angle it 1/8" thick 2" x 2" 7" long (4 Holes)
    A 2" piece is welded over the top as shown (centered, with 1 Hole- also centered)
    The flat unit is 1/8" thick 2" x 4" (5 Holes)
    - If you are in Southern California that would be a plus.
    Material will be provided, I just need a quote on the work.
    No painting will be necessary.
    Thank You
    Aug 2010
    128
    quote questions
    PM sent.
    Jan 2012
    25
    Please note. Metal will be provided in 20 ft lengths.
    Cutting, welding, & Drilling/Punching is required.
    Holes & edges de-burred.
    The weld bead does not need to be filed.
    I will need this order every 2 months so I need someone who can do a
    very good job on this, and offer a good price.
    Thank You
    Sep 2011
    Smile
    PM sent, thanks.
    Regards
    Hugo
    Jan 2012
    Can you provide layout drawings for what you are trying to accomplish?
    Oct 2009
    26
    Job Quote
    PM'd my quote. If you didn'y receive please PM me an e-mail address that I can send it to.
    Jan 2012
    Jan 2012
    25
    Quote Originally Posted by IHscout View Post
    I received it. Thank you
    Mar 2009
    62
    I sent you PM, If you did not get it, Please let me know.
    CD
    Feb 2005
    753
    Quoted.
    May 2004
    4519
    I would like to know how you are quoting without a drawing or specs with tolerances.
    I gave the fellow an estimate, but won't give a firm quote without a drawing and some tolerances.
    If he hits you back with +/-0.001 on hole position and +0.0005/-0.0000 on hole sizes, what are you going to do?
    Mar 2009
    62
    Don’t let this type of fear mongering scare you away from giving somebody what you feel is a quote.
    The guy gave you some pictures and some dimensions. That is what your price is based on, nothing more or less. Maybe throw in some common sense.
    Tolerance is his responsibility. No flatness callout, means if it springs after I mill it, it’s your problem. No circularity call out, maybe you get an oval hole. No call out, no problem.
    If you buy a shed that is advertised as 10ft x 10ft and it actually measures 9ft 11in x 9ft 10in what are you going to do about it? Nothing, Exactly. It’s just understood.
    I do agree with the idea, you should always have things hammered out, in writing before the work begins, so everyone walks away happy. That builds good relationships. You don’t want to screw a guy’s part because he has a new draftsperson.
    Jan 2012
    25
    JOB AWARDED.
    Thanks CNC.
    Many new jobs coming soon.
    May 2004
    4519
    Quote Originally Posted by D3Spindles View Post
    Did he ever send you drawings? He awarded the job a week ago but never sent me drawings or otherwise responded to my private message.
    Jan 2012
    Quote Originally Posted by txcncman View Post
    Never provided drawings.
    Jacksonqin0305 Guest
    Re: Quote Needed for small parts 2,000 pieces
    Hey,guys,this is Jackson, mechanical manufacturing engineer with extensive field knowledge and work experience, my factory located in the world manufacture base center Dongguan/Shenzhen,China,your consultance of fabrication field of here always welcome,by the way,we offer Lathe and Milling/sheet metal fab/parts stamping service, any in need,
    Just contact me,[email protected],thanks
  1. RFQ- Small Delrin parts 140-250 pieces
    By Erik D_lux in forum Employment Opportunity
    Last Post: 07-10-2015, 06:09 PM
  2. Quote needed, mill work, 2 pieces
    By paulcad in forum North America RFQ's
    Last Post: 02-04-2013, 06:42 PM
  3. Need quote for short run of two small parts
    By chrisnis in forum North America RFQ's
    Last Post: 06-15-2012, 06:12 AM
  4. Need quote for small parts for audio amplifier
    By Bellatone in forum RFQ (Request for Quote)
    Last Post: 04-05-2011, 07:50 PM
  5. RFQ small aluminum pieces both mill and water/laser jet parts
    By ahaidet in forum Employment Opportunity
    Last Post: 02-04-2011, 03:05 PM
