Howdy, I'm sure this has been debated before, but I'm having a bit of trouble visualizing the ideal setup for my situation.
I'm designing and building a 3 axis CNC mill, making the frame out of Bosch extrusions, etc. It'll be a moving X, fixed gantry setup.
Anyway, here's my question. I want to be able to mill aluminum parts - I realize it won't be the most amazing mill out there considering my budget, skills, etc. But I do want to have a few inches of Z travel to I can work with pieces that aren't necessarily flat. The problem with most of the DIY systems I've seen is, the Z clearance is limited by the height of the Z axis carriage, not so much the total available travel. This probably doesn't make sense, so I'll try to paint a picture with words
Let's say I build my gantry so that the lowest point on the Y axis carriage is 10" away from the table. Great. Now I add my Z axis and I have 2 options. I can mount the Z axis so that it's lowest point lines up with the lowest point on the Y axis carriage. That means I have lots of clearance, and I can move my work pieces up using blocks/raisers to meet the tool. But if I need to raise the tool more than a couple inches, the carriage itself with now be the lowest obstruction. Hard to explain what I mean, but I'll attach a picture that might help clarify.
Would it be possible/wise to do it the other way around? Instead of having a static (in Z) carriage/motor/rails assembly and a moving platform attached to the ballnut on the ballscrew that the tool is bolted to, could the ballnut and bearing blocks be attached to the Y axis (so they remain static in Z) and the whole rails/motor/screw/tool holder and tool move up and down? I realize it would add a lot of extra load to the ballscrew and rails, but wouldn't it add a lot of usable clearance?
Thanks in advance for any comments.. Sorry if my terminology is way off!
