586,114 active members*
3,245 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > New User - Error Message Help
    Mar 2011
    Question New User - Error Message Help
    My 4400 drops into alarm mode as soon as I power up the controller. Screen reads :
    <NC ALARM> ALARM DIAGN 1
    S04 AMP CONNECT OFF
    Y04 AMP UNEQUIPPPED
    <STOP CODE>
    <ALARM MESSAGE>
    <OPERATOR MESSAGE>
    I thought I had isolated it to the valve which controls the clamp/unclamp cylinder. Replaced the valve (actually had to scab a new valve in, as the OEM Taiyo valves are no longer available in the US) and the problem went away, only to recur on the next start up. I can't really make heads of tails or the O&M manual with regard to alarms and troubleshooting.
    I'd really appreciate suggestions, as I'm desperate to get this machine back up and running.
    Mar 2011
    Update: Traced this to the Freqrol FR-SFJ spindle controller which was on life support. Would never have guessed this from the symptoms.
    Jun 2006
    3063
    I have an old Frequol drive of unknown type and condition at home (I'm not there now)). Email me if you'd like to explore the unlikely possibility that is the same model number as yours.
    Mike
  1. "master encoder state error" AB ultra100 error message
    By ShapeShaver in forum Servo Motors / Drives
    Last Post: 07-31-2013, 04:09 PM
  2. Error message
    By sethren in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-22-2011, 08:28 AM
  3. NX5 Error message
    By FatFingers in forum UG NX
    Last Post: 08-09-2011, 05:14 PM
  4. Send text message for the user in EIA/ISO
    By brenato in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-04-2011, 03:49 PM
  5. G83 error message
    By HBFixedGear in forum Fadal
    Last Post: 01-30-2007, 04:42 PM
