586,114 active members*
3,313 visitors online*
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Jun 2006
    2512
    Quote Originally Posted by MFchief View Post
    I especially like that it can handle curved surfaces without having to go to a 4th axis.
    I don't think it is in any way a substitute for a 4th axis. It's advantage is its' ability to handle irregular, uneven surfaces, within a limited Z axis range. The limitation will be that the greater the range the greater the variation in cut depth.
    Phil
  2. #22
    Oct 2005
    378
    Quote Originally Posted by philbur View Post
    Phil
    Philbur, It sounds like you have been answering many of your own questions. Here are a couple of real world videos of the 2L engraving on a curved surface. As far as eliminating the 4th axis, I would say it certainly reduces the need for it.
    [ame=http://www.youtube.com/watch?v=gjVpr_u0PVo]cnc spring loaded engraving tool scorpion - YouTube[/ame]
    [ame="http://www.youtube.com/watch?v=_1f4w9VOyaI"]hammer of thor engraved whisky flask titanium - YouTube[/ame]
    Magma-joe
  3. #23
    Jun 2005
    656
    As the feed rate dictates the depth of cut I guess you possibly need gcode based on constant velocity mode.
    Phil
    That still doesn't entirely solve the problem. Since Z is spring-loaded, if you spend more time in one place than another, it gets cut deeper. So Z-feeds especially end up deeper than desired. As do places where engraving lines cross each other.
    It's still a handy thing for uneven surfaces since those are a real pain without something like that, but it's not the answer to everything.
  4. #24
    Jun 2006
    2512
    There is an attachment call a depth limiter or some similar name?
    Phil
    Quote Originally Posted by shred View Post
  5. #25
    Oct 2005
    378
    Phil
    Philbur, Its called a depth control control engraving system. It is an accessory for the spring loaded tool, adjustable by .001 depth and used for very soft metals. I don't have one so I can't comment on how well it works.
    I can say this, spring loaded engraving tools are nothing new and have been used for a long time on dedicated engraving machines. They work well and are used on different types of materials.
    2L just happened to patent a tool to fit in a mill. I attached a video of a rotary spring loaded engraving spindle commonly used on router / engraving machines. Same concept and they are adjustable by .001 increments as well. The engraving bits are loaded from the top of the spindle. The spring loaded spindle in the video sells for about $400.00 US.
    2L depth control
    Depth Control Engraving with the Spring Loaded Engraving Tools
    Vision Engraving Spindle Video
    [ame=http://www.youtube.com/watch?v=WCEcTeI4054]Vision Engraver 24 Series - YouTube[/ame]
    Magma-joe
  6. #26
    Jun 2005
    656
    Don't get me started on 2L's patent...
    I've not tried the 'nose' piece, but it sort of defeats the purpose of engraving on uneven surfaces.
  7. #27
    Sep 2008
    20
    Check out Harvey Tool - Harvey Tool > Carbide Miniature End Mills, Diamond End Mills, Carbide Long Flute End Mills, Carbide Long Reach End Mills
    I use many of their engraving tools - excellent quality.
  8. #28
    Re: Engraving Tool Advise
    Your cut looks a lot deeper then .010". Can I confirm your numbers here? Thx
  9. #29
    Jun 2006
    3063
    The entire thread is over 10 years old so you may not a response.
Page 2 of 2 12
  1. Need tool and start advise.
    By jingles in forum WoodWorking Topics
    Last Post: 07-29-2013, 03:53 AM
  2. Letter-engraving tool
    By Vard in forum Wood Lathes / Mills
    Last Post: 03-29-2012, 11:53 PM
  3. Engraving Advise Needed
    By Blanshan91 in forum Engraving Machines
    Last Post: 01-09-2008, 05:23 PM
  4. Tool presetter advise.
    By glovebox20 in forum Calibration / Measurement
    Last Post: 08-10-2007, 11:37 PM
  5. Cleaning Up vector files for CNC Engraving? Advise Please
    By Bretto in forum Uncategorised CAM Discussion
    Last Post: 07-25-2006, 08:26 AM
