586,060 active members*
3,432 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Surface/Solid Fillet Issue
    Sep 2010
    183
    I would like to know how to properly draw the attached file. I would like to know how to get a fillet between the red "floor" & blue "wall" (.250"). Thanks for any help here. The file is a compressed .BBCD. Using V24.
    VPL
    Attached Files Attached Files
    Dec 2008
    4548
    Select "Solid boolean add" and then select the 2 solids and hit the spacebar for "OK". The run the fillet command and select the floor as the geometry and select ok.
    Sep 2011
    I have attached a modified drawing that will allow filleting of the surface. Make sure that you select the lines to the surface and not the top of the surface. There seems to have been an inconsistency to the surface that was causing it to error. What I did was resurfaced the model to eliminate any inconsistencies in the solid. Enjoy
  1. Problem With Solid Fillet
    By missing link in forum BobCad-Cam
    Last Post: 03-28-2011, 06:02 PM
  2. Fillet text in solid in V24?
    By nelZ in forum BobCad-Cam
    Last Post: 02-22-2011, 08:37 PM
  3. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  4. from solid to surface
    By nabil_elbadri in forum Solidworks
    Last Post: 04-29-2009, 07:07 PM
  5. fillet in a solid v22 ???
    By hall6ppc in forum BobCad-Cam
    Last Post: 12-20-2008, 09:16 PM
