586,106 active members*
3,062 visitors online*
    Jan 2012
    29
    Optimisation problem for 3D Milling
    Hi guys,
    Hope you can help me out with this. My problem is shown in the attached screenshot.
    I'm very new to all this but what I'm trying to do is do a finishing pass with linear step over pattern the problem after completing a step over SolidCAM is electing to move the tool up the Z axis, position across to the next step over and then move the bit back down. This is highly inefficient in terms of machine time but I have no idea how to avoid this with my somewhat limited knowledge.
    Any help would be greatly appreciated!
    Jan 2010
    81
    Try using a zig zag if you haven't already and angle along the path for Z entry stratergy. Maybe also try working on selected surface and not a boundary box. It's been years since I used 3D milling as HSM is much better for controling this type of toolpath.
    Oct 2007
    13
    Go to the Link tab. There is a box with Stay on surface within gap of: set the between paths number to about 200% of your stepover.
    Jan 2012
    29
    thankyou I will give that a try
  1. 3D milling problem
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-12-2008, 02:31 AM
  2. Can you get program optimisation software?
    By richardwilton in forum Commercial CNC Wood Routers
    Last Post: 11-23-2006, 08:36 PM
  3. milling problem
    By chip1964 in forum Fadal
    Last Post: 10-05-2006, 10:29 PM
  4. Problem milling MDF.
    By jimcobalt in forum Material Machining Solutions
    Last Post: 07-31-2006, 09:13 PM
