I am cutting a slot along a length of a part. It goes down the whole length of the part so a potential collision is not a problem. It's a .1" slot and I am using a 3/32" emill (.093) (Is that a bad idea to begin with?).
Basically what I want to do is have the end mill centered on the slot to take some depth cuts (cutter comp off), and then have it turn cutter comp on and take 2 climb cuts (one on either side) to finish the slot.
The problem is- I select the "facing" toolpath is mastercam 9.1, for the first part of this episode to do the depth cuts- telling it I want one pass (as opposed to zigzag). I get a nasty error saying "the tool is not wide enough to face off the part" or something to that effect.
I know! I dont care!!! thats the whole point is to have it undersize. I will not be second guessed on my own machine- by my own machine. Do it.
Any way to get around this? I dont want to use pocket milling because it plunges the end mill. Please help.
