586,112 active members*
2,986 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Y axis grid align failure - alarm 44-6
    Jan 2012
    We have a used cincinnati sabre 1500 and we are trying to set it up, we get the error ' Y axis grid align failure'
    Please help how to align the machine
    Nov 2006
    418
    I don't have my manual here at the house to look up that alarm code, but I'll check it out when I get to the shop. There should be a description in the alarm window as well, do you recall what is says?
    Feb 2011
    423
    This seems to happen when the servos are showing their age. I have a couple that act this way sometimes. The first thing I do is energize the servos and let it sit and idle for around 15 mins. Then perform the alignment routine with the
    feedrate at around 30%. YMMV
    Nov 2006
    418
    I didn't find that alarm code in my manuals at all... As I mentioned, the alarm description may help determine what direction to go....
    Does your machine uses encoders and limit switches or does it have linear glass scales? If it has scales you may need to see if you can clean it. This has taken care of my problem more than once.
    Rgds,
    John B
    Oct 2008
    123
    hello Paneltec.
    send an e-mail to [email protected] with a phone number and i'll talk you thru the align fix
    regards
    mallardfizz
  1. ATC TURRET FAILURE and ALARM
    By scadvice in forum Fadal
    Last Post: 03-29-2011, 05:36 AM
  2. Grid Shift C-Axis
    By SchlowMo in forum Fanuc
    Last Post: 10-19-2010, 06:44 AM
  3. 3rd axis turret need grid Shift ! but how ?
    By mte.jalal in forum Daewoo/Doosan
    Last Post: 09-02-2009, 04:26 PM
  4. Align Honing or Align Boring ?
    By jonbanquer in forum MetalWork Discussion
    Last Post: 11-09-2008, 04:33 PM
  5. How do I tram/align the 4th axis to tailstock?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 10-30-2006, 02:25 PM
