We have a new NL2500 with sub spindle and its the only Mori in the shop so all this is new to me...I am understanding the conversational programming a little more everyday but seem to have the most trouble with the milling process.
I am trying to mill a square with a X axis or O.D. live tooling holder using Y axis.
The material is 2 inch dia. and the square is 1.375 and it is from Z.0 to -Z 2.687 using a .75 endmill.I end up cutting in from z zero .150 and leaving stock on end and when looking at the simulation it is not going to full 2.687 location.
I also need to put a .687 radius on the end of the 1.375 square at Z.0 using the side of the end mill.
I am sure this is done easily thru capps, but when all you have is the Capps manual it is not all that clear and there is a lot of trial and era....mostly era!
Thanks for any help
