586,077 active members*
3,591 visitors online*
Results 1 to 6 of 6
    Feb 2010
    60
    Bad Number Format error
    I have a complex part with a lot of arcs meeting other arcs, and I'm getting this error
    "bad number FormatLine 15"
    N15G01Z-0.0625F30.0
    N16X2.3023Y2.4519F***.0
    I made the g-code with Dolphin CAM.
    F***.0 is most likely your problem. Probably due to your Dolphin post.
    Feb 2010
    60
    The post is MACH_3 and it's new. Now that I know that F = feedrate, should I just put a feedrate there?
    Sure, but it'll get old after a while. I'd talk to Dolphin and find out what's causing the problem, and get it fixed.
    Feb 2010
    60
    We haven't solved it yet, but it only happened when I put a Z feedrate of 44in/min in the cam program. When I leave it the default 1.25in/min it doesn't happen. I'm using a new Post Processor that dolphin sent me, the problem I got now is that the finishing passes are offset to the positive X side causing a side step for every Z level. See these photos:
    This circle doesn't have that offset it but it's no perfectly round.
    Feb 2010
    60
    The G codes looks ok as far a I can tell. Here's the g code for the rectangle witch also has the offset finish problem.
    ;( CNC File :- 5square )
    ;( Produced :- 16:10:33 Sunday, January 22, 2012 )
    ;( Post Processor :- M_Mach 3_inc )
    ;( Part Number ID :- )
    ;( Tools Used )
    ;( T01 0.125 End mill)
    N 20 G00 G20 G17 G90 G40 G49
    N 40 M05
    N 50 X0.0 Y0.0
    N 60 M06 T01
    N 70 M03
    N 80 S500
    N 90 G04 P2.0
    N 100 M08
    N 110 Z0.125 F5.0
    N 120 G01 Z-0.025 F1.25
    N 130 Y0.0345 F5.0
    N 140 X-0.1595
    N 150 Y-0.0345
    N 160 X0.1595
    N 170 Y0.0345
    N 180 X0.0
    N 190 G03 Y0.0 I0.0 J-0.0173
    N 200 Y0.1035 I0.0 J0.0518
    N 210 G01 X-0.2285
    N 220 Y-0.1035
    N 230 X0.2285
    N 240 Y0.1035
    N 250 X0.0
    N 260 G03 Y0.0345 I0.0 J-0.0345
    N 270 Y0.1725 I0.0 J0.069
    N 280 G01 X-0.2975
    N 290 Y-0.1725
    N 300 X0.2975
    N 310 Y0.1725
    N 320 X0.0
    N 330 G03 Y0.1035 I0.0 J-0.0345
    N 340 G01 Y0.0
    N 350 Z-0.05 F1.25
    N 360 Y0.0345 F5.0
    N 370 X-0.1595
    N 380 Y-0.0345
    N 390 X0.1595
    N 400 Y0.0345
    N 410 X0.0
    N 420 G03 Y0.0 I0.0 J-0.0173
    N 430 Y0.1035 I0.0 J0.0518
    N 440 G01 X-0.2285
    N 450 Y-0.1035
    N 460 X0.2285
    N 470 Y0.1035
    N 480 X0.0
    N 490 G03 Y0.0345 I0.0 J-0.0345
    N 500 Y0.1725 I0.0 J0.069
    N 510 G01 X-0.2975
    N 520 Y-0.1725
    N 530 X0.2975
    N 540 Y0.1725
    N 550 X0.0
    N 560 G03 Y0.1035 I0.0 J-0.0345
    N 570 G01 Y0.0
    N 580 Z-0.075 F1.25
    N 590 Y0.0345 F5.0
    N 600 X-0.1595
    N 610 Y-0.0345
    N 620 X0.1595
    N 630 Y0.0345
    N 640 X0.0
    N 650 G03 Y0.0 I0.0 J-0.0173
    N 660 Y0.1035 I0.0 J0.0518
    N 670 G01 X-0.2285
    N 680 Y-0.1035
    N 690 X0.2285
    N 700 Y0.1035
    N 710 X0.0
    N 720 G03 Y0.0345 I0.0 J-0.0345
    N 730 Y0.1725 I0.0 J0.069
    N 740 G01 X-0.2975
    N 750 Y-0.1725
    N 760 X0.2975
    N 770 Y0.1725
    N 780 X0.0
    N 790 G03 Y0.1035 I0.0 J-0.0345
    N 800 G01 Y0.0
    N 810 G00 Z0.125
    N 820 Z0.25
    N 830 Z0.125
    N 840 G01 Z-0.09 F1.25
    N 850 Y0.0375 F5.0
    N 860 X-0.1625
    N 870 Y-0.0375
    N 880 X0.1625
    N 890 Y0.0375
    N 900 X0.0
    N 910 G03 Y0.0 I0.0 J-0.0188
    N 920 Y0.1125 I0.0 J0.0563
    N 930 G01 X-0.2375
    N 940 Y-0.1125
    N 950 X0.2375
    N 960 Y0.1125
    N 970 X0.0
    N 980 G03 Y0.0375 I0.0 J-0.0375
    N 990 Y0.1875 I0.0 J0.075
    N 1000 G01 X-0.3125
    N 1010 Y-0.1875
    N 1020 X0.3125
    N 1030 Y0.1875
    N 1040 X0.0
    N 1050 G03 Y0.1125 I0.0 J-0.0375
    N 1060 G01 Y0.0
    N 1070 G00 Z0.125
    N 1080 Z0.25
    N 1090 G28 Z0.0
    N 1100 M30
  1. Error number 8
    By danielmk333 in forum Fadal
    Last Post: 12-16-2010, 10:03 PM
  2. Replies: 4
    Last Post: 10-06-2010, 06:29 PM
  3. Error Code 243 Bad Number ?
    By Rocko1 in forum Haas Mills
    Last Post: 03-03-2010, 02:49 PM
  4. Replies: 8
    Last Post: 10-30-2007, 12:23 PM
  5. Line Number Range Error
    By gar in forum Haas Mills
    Last Post: 05-23-2006, 11:06 PM
