586,082 active members*
3,585 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > Gear_Num setting clarification
    Mar 2011
    525
    Hi Guys,
    This is my second build using the DMM setup and I am still a bit confused about the Gear_Num setting in the Driver setup software.
    I understand that Gear_num = 500 means that it takes 2000 steps to turn the motor 1 revolution.
    What I don't quite get it how that relates to mach3 and if it is better to have a higher or lower gear_num setting.
    As an example I will use the current machine I am building:
    With a Gear_Num setting of 500 and a belt reduction of 3:1 on the machine
    with .5 mm screws I get a steps per inch setting of approx 30,000 in Mach3 with approx 120 IPM.
    As the Steps per inch increase in Mach3 my IPM capability goes down. So would is be better for me to go back to and reduce the Gear_Num down to say 200 or 300?
    What is the trade off? Does more steps per inch put more load on MAch3 possessing power? Is that why the available IPM goes down as the Steps per go up?
    Thank you for the help
    Video of the testing
    [ame=http://www.youtube.com/watch?v=qnSOV_bvKtU&context=C3fd6d75ADOEgsToPDskKj Id5-T5dhBsaHYv5VVAOx]Testing new CNC under Mach3 - YouTube[/ame]
    Kelly
    www.finescale360.com
    15362
    kregan
    Set it to the lowest number which is 500, You dont need to worry about it at all, if you were using the smoothstepper or a board like it that was putting out millions of pulses, then you can use this for the Electronic gearing
    Mactec54
    Mar 2011
    525
    Great, Thank you!
    I always scratched my head about that setting!
    Kelly
  1. Need Clarification of G54
    By gtrrpa in forum Haas Lathes
    Last Post: 04-11-2011, 04:54 AM
  2. microstep clarification
    By stirling in forum Gecko Drives
    Last Post: 09-11-2010, 06:57 PM
  3. 5 axis clarification
    By gravyblue in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-22-2010, 12:54 AM
  4. Clarification
    By IQChallenged in forum Community Club House
    Last Post: 06-27-2008, 04:59 AM
  5. Clarification wanted on G83 G98/99
    By Al_The_Man in forum G-Code Programing
    Last Post: 04-24-2007, 12:30 AM
