586,069 active members*
3,721 visitors online*
    Apr 2010
    Smile Jinan Quick CNC Router Co., Ltd. Ally
    Dear Friends,
    This is Ally from Jinan Quick CNC Router Co., Ltd.
    We are the main manufacturer of cnc machine and laser machine in China.
    If you are interested in our machines, pls feel free to write to me or talk with me by phone.
    Best
    Ally
    Skype: allyquick
    Company:Jinan Quick CNC Router Co., Ltd.
    Add: Lanxiang Road, Tianqiao Industry Zone, Jinan, Shandong, P.R.China
    Webite:
    China CNC Router, Laser Engraving Machine, CNC Lathe Manufacturer - Jinan Quick CNC Router Co., Ltd. (quickcnc)
    Attached Thumbnails Attached Thumbnails K45-3.jpg   Taiwan Syntec Control System.jpg   彩标.jpg   workshop.jpg
    Sep 2011
    10
    Re: Jinan Quick CNC Router Co., Ltd. Ally
    Hi my name is Abel, I have the following machine, of your manufacture..
    I need help, machine has not worked in 6 months and can´t find anybody to reconfigure..
    The problem is one morning router can not go to home, Z sometimes X continuesly runs looking for home..
    Please provide proper table size or diagnostic procedures...
    Attachment 458752 Attachment 458754
    Sep 2011
    10
    I must add, home sensors/switch are new and good working order...
    Quote Originally Posted by abel2b View Post
    Hi Abel. It seems that machine is not sensing the sensor plates.
    Ideally when you start the machine and select "home", it will home Z first. Once Z is home position, it will go for X & Y home simultaneously.
    If it does not sense automatically, try to sense the X & Y home sensors (plates) manually with some metallic items. (Red light in sensor should blink).
    If it does not home and machine continues to travel in home direction, at some point it will be stopped by mechanical stopper in the gantry and table, and you should see a C90 error in your servo/stepper drive.
    I believe this a K60MT model with 6kw spindle. I have used one from the same company for 6 years with satisfactory results.
    Snehal
    Sep 2011
    10
    Quote Originally Posted by Snehal_Shah View Post
    Snehal
    Sorry for the lateness, no solution yet, I tested sensors and are in good working order, I think machine doesn´t have mecanical stopper, cause when it reaches home it tries to continue causing it to bump and grind hard, I have disconnect power to impede damage... a couple of local "techs" have seen it and can not repair.... I might have to go for PC based control....
  1. Jinan Quick CNC Router Purchases
    By rocket67 in forum Chinese Machines
    Last Post: 01-13-2019, 09:54 PM
  2. Jinan Quick CNC Router - K60MT
    By Andre09 in forum Chinese Machines
    Last Post: 10-26-2012, 10:38 PM
  3. Jinan Quick Fulltec CNC Machining Center Ally
    By Ally in forum Chinese Machines
    Last Post: 03-20-2012, 07:43 AM
  4. JINAN QUICK CNC ROUTER CO
    By garychief in forum Chinese Machines
    Last Post: 04-02-2010, 01:48 AM
  5. Jinan Quick Router advice
    By cambridgecnc in forum Chinese Machines
    Last Post: 02-06-2010, 12:25 AM
