586,362 active members*
3,335 visitors online*
IndustryArena Forum > CAM Software > UG NX > Starting at midpoint
    Nov 2005
    244
    Is there a setting anywhere in UG NX6 to start and overlap at the midpoint of a contour toolpath? I am using the curve definition to create the toolpath.
    Thank You
    Sep 2009
    78
    I don't recall seeing overlap in a contour operation. However, if your floor is a flat, planar surface then you could use z-level profile, face milling or planar milling, which all have overlap capabilities. I tend use contour milling only on 3-d geometry and use the other operations where 2.5d cutting work fine.
    NX 10.0.3
    Feb 2006
    146
    It depends on the Drive Method- When using a boundary drive method you can select a cut region start point to indicate where you would like to tool to engage into the cut.
    With other drive methods it will depend on the geometry, however if you define a "Start Point" under the avoidance tab that does not necessarly mean the cut path will start relative to the start point. You may need to modify the drive geometry to force teh tool to start is a particular area.
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
  1. just starting out.. help
    By flekka in forum Machine Created Art
    Last Post: 08-02-2011, 08:03 PM
  2. Starting Out ... VF-2
    By SDS510 in forum Haas Mills
    Last Post: 06-07-2011, 03:04 PM
  3. locate midpoint...
    By junior33 in forum Fadal
    Last Post: 09-24-2008, 01:10 PM
  4. Replies: 2
    Last Post: 06-30-2008, 09:54 PM
  5. Just starting to look...
    By neeboy in forum DIY CNC Router Table Machines
    Last Post: 03-17-2008, 01:56 AM
