586,067 active members*
5,098 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 911 ram party (High) Mori Seiki ZL45
Results 1 to 13 of 13
    Jan 2009
    117
    I dont know what is the problem with. is there any body use like this machine Mori Seiki ZL 45 (Double turret Machine)?
    Oct 2007
    49
    Quote Originally Posted by Asfar View Post
    I don't use that machine, but I suspect it is a RAM PARITY error not ram party !
    There is a problem with the memory in your controller, it is unlikely to be simply a loose terminal, it is more likely that the controller has been affected by static electricity.
    The RAM chips need to be replaced, if you are lucky the rest of the controller will be OK.
    edit: it could be just one RAM chip.. but rarely worth only replacing one.
    Sliding down the razor blade of life.
    Jan 2009
    117
    i think i need to clear this memory and upload again all prameters. but i dont have any parameters. how can i get parameter list.
    Oct 2007
    49
    PARITY errors are normally a hardware issue, also it is a RAM issue.
    Sorry can't help you with getting parameters list.
    Aug 2011
    2517
    can you still access the parameter screen?
    Jan 2009
    117
    Quote Originally Posted by fordav11 View Post
    yes brother still i have the screen(911ramparty high message).this is double turret machine
    May 2009
    106
    Hold On! first which control ?
    Then , are you sure you can access the parameter screen?
    Next is the ram parity alarm constant?
    Jan 2006
    121
    Please post the Fanuc control model and serial number of the machine.
    Aug 2011
    2517
    Unless you work for Fanuc and have access to technical info and original factory parameter backups the serial number is not required to fix it.
    The solution is of course to power on while holding certain keys so the SRAM memory is cleared then re-load the parameter backup. Although this task is usually not easily achieved by a novice.
    The OP first needs to ascertain if he can still punch out the parameters while the alarm is there. that includes the PMC parameters too!
    Jan 2006
    121
    I am merely asking for machine serial number to see if I have data backup for a machine close to that. Oh, and if i am a Fanuc employee or a "Fanuc police", screen name "fanuservicetech" is an obvious choice...
    Jan 2009
    117
    Quote Originally Posted by fanuservicetech View Post
    Thanks a lot for your coments regarding my problem to everybody. this is my machine details:
    Machine Type: Mori seiki ZL 45
    Serial Number: 102
    NC Type: MF-D4
    Code No: 93010434
    Jan 2006
    121
    sending info via PM.
    Apr 2009
    1379
    On NO Fanuc control that I know of can you do anything other than clearing the memory when you have a system alarm, especially a RAM PARITY one.
    There is no access to any other screen.
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. MORI SEIKI JR
    By CNC2NUT in forum Mori Seiki Mills
    Last Post: 05-03-2011, 12:39 AM
  3. mori-seiki
    By ron2008 in forum Mori Seiki Mills
    Last Post: 10-08-2008, 09:22 PM
  4. Mori Seiki SL3
    By sudhirudar in forum DNC Problems and Solutions
    Last Post: 05-21-2008, 07:29 AM
  5. Mori Seiki SL-204
    By dcworld in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2007, 04:25 AM
