I recall a post from someone who had done tests on the AMT102 encoder and reported processor time delays in the quadrature signals coming the encoder.
A failing on my part was at the time it didn't have relevance to what I was doing so I neglected to note the name of author or investigate his findings. My error then has now taken on an unexpected urgency now and I would dearly love to revisit what he found.
Let me give a little bit of background for what prompts this request. This is kind of technical so feel free to tune out here.
I have pursued designing a step-motor servo for over 12 years. All of my attempts from all different directions over the years met with failure. It also puzzled why no one else had come up with one.
A successful solution is one that uses the Clark-Park and inverse Clark-Park transform equations. In literature these transforms are universally solved using DSP-enabled microprocessors for brushless DC motors.
Brushless-DC motors, properly called PSMS (permanent magnet synchronous motors) typically have 6 poles. The microprocessor running them can barely execute the firmware in 50 microseconds (20,000 times a second).
A step motor, (also a PMSM motor) has 50 poles instead of 6 poles. The math transforms would have to execute over 8 times faster (50 poles / 6 poles). This is beyond the ability of any microprocessor to handle.
Of the transforms, the Clark transform and its inverse is more trivial. It converts a rotating 3-phase vector into an orthogonal rotating 2-phase vector. A step motor is an orthogonal 2-phase motor to begin with so the Clarke transform and its inverse can be discarded.
The Park transform converts a rotating 2-phase vector to a stationary reference. The servo PID magic is applied to stationary vector and the inverse Park transform restores it to a rotating vector to move the motor.
The problem is the Park transform requires requires 4 multiplications by sine and cosine and its inverse requires 4 more multiplications by sine and cosine for a total of 8. At 6.000 RPM, these calculations and the sum of the products as well as 2 proportional-integral calculations have to be done in 5 microseconds. This cannot be done even with a fast MCU.
I just found a way around this problem and then some and it doesn't involve an MCU at all. It works so well I destroyed some perfectly fine NEMA 23 step motors well past 18,000 RPM (the motor ball-bearings failed). The Park transform and its inverse is solved using an analog circuit technique.
Regards to the encoder and my original request. The Park transform yields intermediary results in the form of D and Q signal components. Both decompositions were expected to be near constant DC volt values yet they were not. There was considerable modulation on these signals indicating there was a phase delay from encoder signal.
This calls into question the signal phase delay integrity from the encoder. I'm hoping the author of the AMT102 encoder study will respond. Otherwise I will have to revert to using an optical encoder.
Mariss
