586,675 active members*
2,904 visitors online*
    Nov 2011
    3Axis mimic 5Axis?
    Which software can make my 3Axis CNC produce 5Axis results? No really, I'm being serious. I'd like to have software create 4 GCode files on a single object. Each would be processed in turn such that a woodblock could be positioned on its front, back, left, and right and the respective file could be processed to ultimately render a 3D Object. The woodblock would have to be mounted in a way that the 4 rotations could be predicted but that wouldn't be hard to solve.
    Does such a thing exist?
    Andy
    Aug 2011
    how about you just use any old cam, then use some kind of rotation command, which most cam can do. then you define your zeros correctly and align and fixture your part correctly (handwavingly saying this which is the hardest part), then make a nc file for each rotation. You will get 5 axis camming this way.
    May 2006
    803
    SHOW US THE PART, USUALLY NO PROBLEM TO GET RESULTS, DONE 5AXIS ON 3 MACHINES MANY TIMES.
    Been doing this too long
    Nov 2011
    I have a manual process for doing this but it add 10 minutes per size due to the extra workflow involved in manually flattening vertices on the opposite side. I was looking for software that could save me time.
    Andy
  1. 3axis to 5axis
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-02-2011, 05:02 PM
  2. Replies: 0
    Last Post: 11-09-2009, 06:25 PM
  3. 3axis cnc kit?
    By jmacken in forum Want To Buy...Need help!
    Last Post: 11-04-2008, 01:09 AM
  4. 5axis Help
    By jybute in forum Haas Mills
    Last Post: 11-22-2006, 03:10 PM
  5. 3axis DRO
    By Klox in forum DNC Problems and Solutions
    Last Post: 06-04-2003, 07:32 AM
