586,102 active members*
3,022 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mach3 spindle control on X1
    Mar 2007
    171
    Hey
    Can you give me a little guidance as to what is required to set up Mach3 to control my spindle on my little X1 mill?
    I have search and think I need to set up some kind of (optical) sensor on my spindle or motor or something spinny in the gearbox, and I think I need something to convert steps and direction into a 0-10v analogue output. I guess I need something to control relays for on/off and direction.
    The problem for me, is I don't know anything more specific than that.
    Mar 2007
    171
    I found these on CNC4PC.com:
    C41 - PWM Variable Speed Control Board
    CNC4PC
    C3 - Index Pulse Card
    CNC4PC
    Would I be able to connect the 0-10v from the C41 directly to the speed control pot in my X1?
    Do I need the C3 (or similar) to feed back the spindle speed, or will Mach3 operate without it?
  1. Which VFD for spindle control Mach3 via Modbus
    By silyavski in forum Phase Converters
    Last Post: 07-06-2011, 01:43 PM
  2. mach3 spindle control on nm-200
    By urbanimports02 in forum Novakon
    Last Post: 01-19-2010, 04:33 PM
  3. Spindle Control Problem in Mach3
    By creativecad in forum Mach Software (ArtSoft software)
    Last Post: 08-07-2009, 12:57 AM
  4. Mach3 spindle control of Boxford 260 VMC
    By jwhitley in forum Benchtop Machines
    Last Post: 09-09-2008, 06:21 PM
  5. VSD-A Spindle control in MACH3?
    By mkuivamaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2008, 08:09 PM
