We use both ProE and UG based on the customer.
My question is when using UG NX6 sketch is there a way to have the dimension from the centerline equal the diameter when sketching?
The way I am do it now is creating a radius but not the diameter.
I ProE I select the sketch curve the centerline I created while in that sketch and then the sketch curve again to get my diameter dimension.
attached are screen shots to help illustrate.
Thank You
