586,102 active members*
2,606 visitors online*
Results 1 to 9 of 9
    Nov 2011
    16
    Hitachi Seiki HG400 III
    We have recently purchased a used HG400 III horizontal. Everything is working fine after we worked a few bugs out. We would like to slow down the pallet change because we are pushing the max load capacity between our tombstone and work pieces. Does any one know if there is a parameter or hydrolic control valve that will do this for us? The machine has a FANUC (SEICOS) 16 M control. Thanks!
    Quote Originally Posted by chrisgraf2 View Post
    Hi!
    I have the same center only with FANUC15B. Looks like it is impossible.
    The oil pressure has to me 70kg/sq.sm, and oil sensor is very simple.
    If you will try to decrease the speed, the timeout will alarm the APC.
    Use it as it is.
    Mar 2012
    Re: slowing down pallet change HG 400III
    If you haven't found it already, the hydraulic solenoid valves under the pallet changer have flow controls on them, you should be able to close them up a bit to slow it down, time out for pallet change is fairly long, I'd have to look it up in the manual. I also have an HG400III in house.
    HITACHI HG400III INSTRUCTION MANUAL
    Hi!
    I scanned and upload HITACHI MANUAL
    You can get files in this link:
    The HITACHI HG400III Seicos Sigma10 manual - CNC Professional Forums
    Feb 2016
    Re: HITACHI HG400III
    We have an Hitachi HG-400III for sale, being removed from service this week. Serial number HG43629, 1998. Seicos 16M. Nice machine, anyone interested?
    The HITACHI HG400III Seicos Sigma10 manual - CNC Professional Forums[/QUOTE]
    Re: Hitachi Seiki HG400 III
    What is the price for HITACHI and the region (country, land)?
    Feb 2016
    Quote Originally Posted by =aike= View Post
    We're looking for 30K loaded. We're in Western Canada.
    Has tool life management; cut monitoring function; thermal compensation; high pressure coolant; scales
    Installed new in 1999.
    Plant went through downsizing in 2010, sold off a lot of equipment, this machine was kept because it was one of their best, and has done little work since then.
    Send your contact info and I will send you pictures. [email protected]
    Hello, Can anyone tell me What could be the problem, My HG 400 II I wrote the correct tool position.
    Thank youClick image for larger version.
Name:	Not write position tools.jpg
  1. Replies: 6
    Last Post: 03-06-2020, 02:11 PM
  2. Navigating Hitachi Seiki HG400 w/ Seicos Sigma 10M
    By kmuller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-13-2016, 02:54 PM
  3. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  4. Hitachi Seiki
    By nicolae in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2009, 08:37 PM
  5. Hitachi-Mori seiki spindle HG400
    By fabshop in forum Mori Seiki Mills
    Last Post: 05-18-2009, 02:08 PM
