586,075 active members*
3,684 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > Dmm Tech Servo Review
Results 1 to 6 of 6
    Nov 2010
    25
    I recently completed our company's first machine, 3GM machining and engineering. We decided to go with DMM Technology Corp. servo's and i am so glad that we did. I will break this review down into category's.
    This review is for the 92GM-DHT-72, Dyn2-H, Power supplies, DMB4250-8B Breakout Board
    Packaging:
    The servo's and driver's arrived in a well sealed box with about 3 fragile stickers on it. I was pleased to see that the items where not crammed into one box. Instead they used 2 boxes, the static and moisture protecting plastic for the breakout board, and all drivers. Very well cushioned from the "gentle" shipping of ups.
    Inspection/Quality:
    Let me start out buy saying that the the enclosure for the Servo motor is all aluminum and very well machined, aligned and assembled. (Unlike some of the cheap stepper motor's i have ran into.)
    The shafts turn very free, and all dimensions lined up according to the Drawing(This was crucial for our design and alignment). Also the encoder is very solid and well attached. The same go's for the Dyn2-H driver very well built. I don't feel like im going to break it by plugging and unplugging cables. The only recommendations is that the mounting holes are kind of small. i would like to see a little larger of a hole in them. Power supplies are your standard 5" switching power supply. Mach3 breakout board also has solid connections and well labeled.
    Setup:
    I am not all that familiar with servo's, I only know what i have read. I have only used steppers in the past. But let me start of buy saying these do not function in the same sense some may be familiar with. They are closed loop between the encoder and the motor, inside the driver. Currently on the Dyn2-H there is no support for encoder output to motion controller via A/A,B/B,Z/Z. This was a little disappointing as i did not read or see that in the literature. Non the less Dmm-Tech and there quick and excellent customer support. Apologized about the literature and website also stated that they where in the process of releasing a new website, a new servo driver, and updated literature. I can't express just how good the communication is with them(via email, i never attempted phone contact but i would imagine it's the same quality)
    moving forward. I Wired all of the servo's, e-stop, and limit switches up and all functioned properly with the breakout board. I used the recommended tuning for the servo's and it works flawlessly. I only wish for the dyn2-H that since there is no encoder output from the driver, that it would display the fault either via a mini mono-chrome lcd or the machine controller. instead of just throwing the estop, in this case you must plug the RS232 into that specific driver and read the error(A tedious task when wiring and speed mistakes are made on our part). On that note the Dyn2-H software is very easy to use and works with no glitches.
    As far as configuring the servo in mach3, The .Xml file given with the purchase has all of the required pin-outs, and step and direction timing already with it. All that is required is you configure your pulses per unit of measurement. On that note the setting suggested in the servo tuning for gear number is 500 for mach3, With help from There trusty tech support i now understand the gear number correctly. I was able to easily calculate what the pulse per inch was, and then adjust for ball screw error from that point. I easily obtain 200 Ipm on the second lowest kernel speed with a 5mm pitch ball screw. Everything else works flawlessly with mach3 i should also state the mach3 breakout board will work with Emc2.
    Final Thoughts
    The motors are virtually silent, and very powerful. Still some improvements to be made as far as adding the "extra features" like specific error reporting, and encoder out(This has been included in there new servo driver but the price has not been set and the launch date is early march. i am patiently waiting to see what this will do for our machine budget i would love to see the 6000 rpm on this servo motor and boost the rapid speeds to 1200 ipm. but i fear the price will bring the servo and driver up to what they should be selling for probably $750.00-$1000.00 per servo driver combo. but this is just a guess. and if its true im sure its worth every penny.)
    I also can't express enough how helpful the tech support is, along with the sales. The tech helped with formula's for changing pitch and calculating the torque required if we were to up our lead to increase speeds. ( Above and beyond what normal tech support is required to do). We will be using the servo with every machine we sell, depending on the price of the new drive we will probably stick to the Dyn2-H, and Design and develop our own Breakout board, possibly add 3 encoders to the end of our lead screw for feedback.
    I hope this is helpful to anyone contemplating buying this system. With the new redesign of the website and new product announcements Dmm is Heading in the right direction. Don't let the lack of discussion and conversation about them full you.
    Gabe
    Nov 2010
    18
    EMC2 and tips
    How is the system running now, also did you actually test it with EMC2, and have any hints for others trying to run the DMM-Tech system with EMC2 or LinucCNC?
    24221
    I do not see what the concern is about the encoder output to the controller when used with Mach?
    If this were a PID loop closed back to the controller, yes, it would be absolutely necessary, but Mach does not close the loop?
    Al.
    Albert E.
    15362
    cncgabe
    You will find that the new drive is not expensive, The price is not much more than the Dyn2 Drives, if you have the need for more speed on the larger motors this is the drive to get,
    Your thoughts as for the Drive mounting, it is best to thread the holes to either 4mm or 8-32 this makes for easy mounting
    I did not see this posting before, so a lot has changed, the Dyn2 will have encoder out put so the loop can be closed in the control, if your control can do this, the New Drives already have this
    I have built a wiring package & mounting Kits for the Dyn2 Drives & are working on a package for the Dyn3 Drives as well
    This is what the Kit for the Dyn2 looks like, this is ready to go, just add power supply & computer The motor in the photo is the same as before with a aluminum Encoder cover for better protection, the cable termination/control is much better also
    Attached Thumbnails Attached Thumbnails 4 Axes Wired Kit-1.jpg   4 Axes Wired-2.jpg   Dmm New Look 400W Motor-4.jpg
    Mactec54
    Nov 2010
    18
    Very neat work. I have there 450W/900W peak motors, are you able to supply any encoder covers for these motors?
    15362
    AussieMatt
    I don't think so, But I will take a look at it, The motor that you have, the design has changed, The new motor the same size 750W is a little different in construction & size, the Aluminum Encoder cover is on all new motors sales
    Mactec54
  1. IMService Servo CNC Router review
    By buscht in forum Commercial CNC Wood Routers
    Last Post: 04-21-2024, 10:46 PM
  2. Need tech data Fenner/Servo Dynamics SFD1525-12
    By calmissile in forum Servo Motors / Drives
    Last Post: 04-30-2010, 09:33 AM
  3. ACS-Tech SB1003/ Anorad D-Serv Servo Controller?
    By macona in forum Servo Motors / Drives
    Last Post: 05-03-2009, 03:13 AM
  4. Okuma Act-3 Servo Problem, Tech wanted
    By KE4GHC in forum Okuma
    Last Post: 03-11-2009, 04:02 AM
  5. Servo and guide found at tech fair.
    By svenakela in forum Mechanical Calculations/Engineering Design
    Last Post: 10-20-2005, 02:42 PM
