This should go close.
The max speeds are reduced.
You can make X and Y 2500 instead of 1500.
The Z can be as high as 1500.
Also acceleration can be increased a bit. I have it conservative, for reliability.
You may have to move the soft limits a bit depending where your homing switch interrupters are located.
I have extended the X limits both ends so you may have to move them in a bit.
It NEVER loses steps, and I don't care how slow I cut air.
This is for early BOB that had 2 relays, for M7 and M8. That won't stop it working for you.
Depends how good the PC is so steps are not lost -- clunking during fast moves.
You might like my improved kiosk.set screen set, for my touch screen.
Some button sizes are bigger.
This is for Mach3 2.26 but should load up for later versions, but use the standard screen set if you are using above 2.26.
The files are zipped, so the stupid browser does not try to open the .xml file.
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
