586,305 active members*
3,606 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Building a 20HP RPC, have questions
    Sep 2011
    77
    I have finally rounded up all the components to get my 20HP Rotary converter built. I went a bit overboard and picked up two 120amp contactors, one each for the main and start contactors. I also picked up various other parts needed to get it going. Below are some pictures of what I have so far.
    My first question is do PRC's generate any heat while they are in use. The reason I ask is that I have a small 120v AC fan I saved from the scrapper. I can mount it on the side of the cabinet very easily. If it doesn't need it then I will leave it out. It can be seen in the pictures.
    I have calculated from various sources that for a 20HP converter I will need approximately 1600uf worth of Capacitors to start it and about 300uf per phase relation for balancing, about 2200uf total. Is this correct or is it too much.
    I picked up a bunch of capacitors for this build and after sorting out the calculated amount I thought to myself, where am I going to put all of these. I can fit 3/4 of the caps across the bottom of the enclosure but I am going to have to come up with something to mount the rest. Perhaps a shelf or something? Any ideas?
    The enclosure I picked up came with some components in it when I bought it, namely 2 sets of 3 phase fuse holders, with 30amp fuses already in them. The fuses are time delay fuses. I thought about using these as my 2 outputs from the converter that go to my machinery. Should I use standard fast burn 30amp fuses or are time delay OK? I ask because I bought two sets of holders for class H fuses and then a week later bought the enclosure which had the holders in it with time delay fuses installed. They are both in the pictures as well.
    Steve
    Sep 2011
    77
    Well I made a little more progress today. My original plan was to use all run capacitors in my converter. Mainly because I got a great deal on a box of new capacitors. After trying to fit the required amount in the enclosure I realized pretty quick that it was not going to work. I talked to a couple friends of mine and decided that going with start capacitors instead of run capacitors for the starting circuit would be best. I started looking around and found some 330v 300-360uf capacitors on eBay. I tried to find them locally and was about to give up when I finally found them. Now I have 5 of them and should hopefully have the assembly done tomorrow.
    All I have to do now is get the sub panel in my shop finished up and wire it all in. I am beginning to see the light at the end of the tunnel.
    Steve
  1. Questions about building CNC Router
    By PortlandGTS in forum DIY CNC Router Table Machines
    Last Post: 07-18-2011, 01:21 PM
  2. Building new machine - questions
    By philba in forum DIY CNC Router Table Machines
    Last Post: 01-12-2010, 10:05 AM
  3. Building JGRO - questions
    By pntbllrsprky in forum Commercial CNC Wood Routers
    Last Post: 11-14-2007, 08:28 PM
  4. Questions on Machining Building
    By kinetic_arts in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2007, 05:32 PM
  5. building first servo, got questions...
    By Seb in forum Servo Motors / Drives
    Last Post: 10-07-2007, 09:05 PM
