I have had a fair bit of success now with V24 milling but have turned my attention to the Turn package. My lathe is "conventional" in that you stand in front of it and the tool is between you and the work. -Z direction is heading up the spindle, -X is taking material off the diameter i.e. moving the tool closer to the machine centre line.
Looking in the "machine info tab in Turn, the graphic shows Z ok but X is reversed i,e going positive toward the job. The tool is also above the job in the graphic i.e. coming from the back of the lathe rather than the front. Looking at the orientation tab I have the same problem, X is back to front.
I know that some lathes are this way round but mine isn't and it would help if the software could look more like my machine.....or have I got hold of the wrong end of the stick?
Ian
