587,404 active members*
3,529 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > Delta Dynapath 10 Repair or retrofit
Results 1 to 1 of 1
Hybrid View
    Jan 2012
    I've a Shizouka mill
    delta dynapath 10
    2 x Servo Dynamic SDFP1525-12 (X & Z axes)
    1 unidentified servo board (Y axis, pictured)
    3 SEM MT30U4-42 servo motors
    the mill is a bit rusted up from condensation. the X and Z axes can move an inch or two in jog before throwing a servo error. the Y axis won't budge.
    I'd like to replace the Dynapath and the mill itself for smaller items transferring the servo motors & controllers.
    can anyone lend advice as to diagnostics for ascertaining faults that lie in my servo boards, motors and Dynapath?
    in my present level of ignorance, I believe I can control the servo boards via a parallel port i.e. this Opto Breakout board and hooking up to a modern sort of computer running fancy software that'll make learning CNC easy (easier than the Dynapath)
    Quentin Llop
    [email protected]
  1. dynapath delta 20
    By dodgetruck23 in forum Want To Buy...Need help!
    Last Post: 10-10-2011, 11:54 PM
  2. DynaPath Delta 20
    By TowerCNC in forum BobCad-Cam
    Last Post: 03-22-2009, 03:36 PM
  3. Dynapath Delta 50 FDD HDD failure. Should I retrofit?
    By bumnog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2008, 04:11 PM
  4. dynapath delta 10 help
    By undertowx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-05-2006, 03:49 PM
