586,080 active members*
3,722 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Obtaining mirror finish on aluminum molds with tiny features
    Jan 2012
    Im trying to make Al alloy molds with small 0.01" and smaller features. The depth can also be equally small. I want to be able to have the mold be essentially mirror finished and smooth so I can cast clear plastic and that it remains optically transparent.
    However I cant use conventional methods like use a buffing wheel etc that you can do on larger mold parts.
    So whats the way to get good mirror finishes on these molds?
    Also critical is that I want the mold to maintain geometry, e.g. 90degree straight edges should remain 90 degree after polishing, so say buffing techniques are sometimes not suitable because they round out edges.
    May 2004
    4519
    What do you consider a mirror finish in numbers? 16 RMS?
    Yes, you can polish features as small as 0.010". There are tools made for doing it.
    Have you considered burnishing?
    You location is listed as "c". Where is "c"?
    Feb 2009
    6028
    We routinely do small profile stuff with less than an 8 finish. Sometimes even in sub nano finishes. All depends on the machine, tooling, and the guy running it. Just cause the part is mirror, doesn't mean the finish is actually good btw.
  1. Mirror finish steel and aluminum parts vibratory bowl?
    By Toggle in forum Material Machining Solutions
    Last Post: 10-18-2018, 10:14 AM
  2. polishing aluminum to mirror finish
    By kling8 in forum Mass finishing equipment/media/strategies
    Last Post: 06-29-2018, 03:00 AM
  3. Bending Stainless #8 (mirror finish)
    By cpcp in forum Bending, Forging, Extrusion...
    Last Post: 09-24-2010, 07:49 AM
  4. I want that mirror finish
    By CORBIN92087 in forum MetalWork Discussion
    Last Post: 09-12-2009, 05:11 PM
  5. Mirror finish on Aluminum?
    By RP Designs in forum MetalWork Discussion
    Last Post: 09-11-2009, 11:05 PM
