586,075 active members*
4,173 visitors online*
    Aug 2005
    300
    Lost or corrupt file
    I used my PCNC 1100 up until this past week. I went out to the garage to play some more and the computer will not boot. Error message reads " Windows could not start because the following file is missing or corrupt sys32\drivers\isapnp.sys".
    I have contacted Tormach about the issue but would like to use the machine today Sunday instead of waiting until Monday for Tormach to respond.
    Has anyone had this problem? Is there an easy fix? Start in safe mode? What then? I am not a computer expert so go easy on me.
    Ernie
    Nov 2010
    360
    Quote Originally Posted by ErnieD View Post
    Ernie
    Is this a Tormach controller, or your own PC? My experience with that kind of message is usually a failing hard drive or corrupted operating system. I have saved a system before with a Windows repair from the install disk, but the drive totally failed within a few days anyway. On another I did the repair and its still running today.
    If its a Tormach controller under warranty, I'd likely wait for them to give you a course of action.
    Aug 2009
    986
    To get to Safe Mode, hit F8 just as Windows starts to boot up. You should get a menu with boot choices.
    Once in safe mode, run Scandisk with a surface scan. This takes a bit, but will find and correct any problems with your hard disk that might have caused the file to corrupt.
    Meanwhile, I can go to my Tormach and get that file off of it, then email it to you. Just send me a private message with your email address.
    Frederic
    Aug 2005
    300
    File
    Hi TXFred,
    PM sent.
    Ernie
    Aug 2005
    300
    dbrija
    Tormach / Dell compiter out of warranty.
    Ernie
  1. Corrupt programs?
    By Most in forum Haas Mills
    Last Post: 04-03-2014, 01:22 PM
  2. corrupt files on 18i-mb
    By ikennedy in forum Fanuc
    Last Post: 11-21-2011, 11:41 PM
  3. Lost xml file settings after upgrading mach
    By jsheerin in forum Mach Software (ArtSoft software)
    Last Post: 03-18-2011, 02:18 AM
  4. Corrupt Software
    By ericwaa in forum Milltronics
    Last Post: 10-08-2009, 10:30 PM
  5. Mastercam X corrupt file
    By tstrajt in forum Mastercam
    Last Post: 09-04-2008, 10:41 AM
