you will not be able to use peel mill as it will not see the taperd walls. I would use may be the HS surface opti rough to remove the stock the you can use a tapered EM to finish the walls or surface the wall with a ball then go back with a sharp EM and surface part way down to get the sharp intersection. just a few thoughts.Like I ask all the time what version are you using as then the options may change.
Cadcam
