586,094 active members*
3,914 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma floppy to usb conversion
Page 1 of 2 12
Results 1 to 20 of 38
    Oct 2003
    530
    I just got an email from our okuma rep with an okuma floppy to usb conversion. You guys see this yet?
    http://www.morrisgroupinc.com/files/...B_flyer-LR.pdf
    Would be nice to get rid of that floppy
    Jan 2012
    14
    Have a look on ebay for item no: 290565580626
    FLOPPY DRIVE EMULATOR
    Aug 2011
    2517
    excellent! I have a few spare paypal bucks lying around so I just bought one. I'll report back when I test it (I have OSP7000)
    Oct 2003
    530
    I've seen the generic versions of these. Just never saw one from Okuma or heard of anyone installing a generic version into there Okuma successfully.
    Aug 2011
    2517
    its basically the same thing but being Okuma branded is has $2000 added to the price. probably no other differences
    Mar 2012
    Any success with the emulator?
    We have an osp7000 that the floppy drive just stopped working. Okuma wants almost as much to replace 3.5 drive as they do to upgrade to usb drive. We have 4 Okuma mills and 2 Okuma lathes. That can get really pricey!
    Jun 2005
    142
    Our MA400H recently had its flood damaged floppy replaced with the Okuma USB floppy emulator.
    It works fine.
    The system is set up to emulate 100 floppy drives.
    The supplied USB memory was a Buffalo branded unit (they recommend only a handful of compatible makers) and is not a particularly satisfying thing to use.
    It is actually a microSD card USB adaptor.
    The fit is so tight into all the ports I've tried it in, that when you use the cord to remove it, the plastic housing comes off.
    It is so small that you can't grip it with your fingers, so the cord is necessary!
    Then while trying to pick it out with fingernails the SD card flies out.
    After finding some needle nose pliers, I did get it out, and had to do the same thing again each time I needed to remove it.
    Aug 2011
    2517
    yes I got it and it works fine.
    Smile i tried it and it works
    Hi
    Just tested product floppy to usb converter from www.floppytousb.net for okuma lathe machine and it works great @ USD$ 65 only
    May 2010
    barry
    Quote Originally Posted by fordav11 View Post
    Where did you buy It. send an email to:
    Okuma spindle drive, Fanuc servo drive, repair, Consulting | CNC Open Solutions
    Aug 2011
    2517
    ebay
    Jun 2013
    Did you purchase the emulator from ebay? If so how do you set the jumpers on the drive and are there any parameters (OSP 7000) that need to be changed?
    Sep 2013
    I bought the floppy to USB but am unable to get it to work , getting error 337 floppy ready error when jumpers are set on anything other than JA and S0, any ideas ?
    Sep 2013
    9
    Here SD card to floppy converter:
    No outward protrusions such as USB.
    No any jumper at all.
    Floppy emulator SD card drive-Floppy emuDrive
    Jan 2015
    Re: Okuma floppy to usb conversion
    Quote Originally Posted by iq370 View Post
    We got one from amazon that had the same problem in both our Okuma mill and lathe. Ordered another one off ebay that worked. Then we tried to go cheaper and by the one that looked like the one that worked, and it turned out to be a different model.
    Seems like the ones w/ a 3 digit display never work, but the one with 2 digit worked. The one we tried to order from amazon showed 2 digits, but we received the newer 3 digit one--didn't work.
    The one that worked, search for ebay #300723408804
    Nov 2016
    Quote Originally Posted by OldOkumas View Post
    Hey
    Does anyone know if this emulator in the quote is just "plug & play" exchangable for the standard floppy drive? Do I need to change any settings in the cnc or at the emulator itself?
    Aug 2011
    419
    if control unit is OSP7000 , you must use 4 jumpers on MO,S1,JA and JB
    if unit is U100, 2 jumpers on MO and JA
    "Imagination is more important than knowledge."
    Dec 2016
    4
    Quote Originally Posted by kurmay View Post
    What would the Jumpers be on a OSP700L?
    May 2011
    4
    Quote Originally Posted by Lawler View Post
    Do you have information regarding to the OSP-U10L???
    At this momento I´m working with this emulator and I don´t know what configuration use to do this propertly.
    I will really appreciate your help.
    Dec 2016
    4
    Anyone have information on this one?
    Sent from my SM-N920P using Tapatalk
Page 1 of 2 12
  1. OKUMA OSP Floppy Simulator
    By kurmay in forum Okuma
    Last Post: 03-10-2024, 10:13 AM
  2. Okuma OSP7000L Floppy to USB?
    By fishtuna57 in forum Okuma
    Last Post: 07-11-2020, 04:07 PM
  3. Floppy to USB Conversion Kit
    By Laser Motion in forum News Announcements
    Last Post: 01-23-2013, 04:12 AM
  4. OKUMA OSP Floppy Reader
    By erdemkaraman in forum Okuma
    Last Post: 08-10-2011, 07:39 AM
  5. okuma floppy needed
    By cinci5 in forum Okuma
    Last Post: 03-06-2009, 02:58 AM
