586,104 active members*
3,371 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Calculating series load resistors
Page 1 of 3 123
Results 1 to 20 of 50
    Oct 2005
    328
    I have noticed on at least a couple of websites and in a few posts here that there is an error in the way the value of the series load resistor is calculated. It seems that people are being advised to take the rated voltage for the motor to be used (V) and divide it by the current per phase (I) to figure the DC resistance of the windings. This is good information. Then, to subtract the motor voltage from the power supply voltage and divide this by the winding current. This would be great if these were the only devices in the current path. However, there is a voltage drop across the switching device, whether using FETs or bipolars transistors. This must be taken into account, especially when using power supplies that are closer to the rated voltage of the motor! It should also be noted that a 5V power supply will not supply 5V across the windings of a motor when put in series with the switching device.
    That's the summary. For those who have the time and want proof...
    As an example, let's assume I have a 9VDC p/s capable of supplying the needed current, and use steppers rated for 5V and 1.6A/ph.
    My series resistor needs to drop 9V(p/s)-5V(winding)=4V.
    Using Ohm's law, we can calculate the DC resistance of our windings. R=E/I, so R=5V/1.6A=3.13ohms. We'll use this later.
    Going back to Ohm's law, our series resistor needs to be R=E/I, R=4V/1.6A=2.5ohms.
    This resistor would need to be able to handle P=IE, P=1.6A*4V=6.4W.
    Right? Wrong.
    Let's factor in the FET that I will use in my example.
    The datasheet says that my FET will have an on drain-source resistance of 1.76ohms(typical).
    Since this is in series with the windings, it will have the same 1.6A of current going through it, so it will drop E=IR, or E=1.6A*1.76ohms=2.82V.
    If we add that to the 5V that we want our motor to "see" we get a total voltage drop of 7.82V. Now when we subtract that from our 9V power supply we get 9V-7.82V=1.18V.
    Back to Ohm's law again, R=E/I, R=1.18V/1.6A=0.74ohms.
    This resistor would need to be able to handle P=IE, P=1.6A*1.18V=1.89W.
    If we use the original resistor value we came up with, we would have a total series resistance of 1.76ohms(FET)+3.13ohms(winding)+2.5ohms(resistor)= 7.39ohms. With the 9V power supply this results in only, I=E/R, I=9V/7.39ohms=1.2A, or 25% less current than we want! With a bigger difference between the supply and motor voltages this is less of a factor, but should still be taken into consideration.
    That's my 2.5 cents.
    Feel free to comment.
    Dave
    Sep 2005
    11
    Dave, you are a right about the FET (switcher) issue, also the same we could and should apply to bipolar switcher, now if you could give me some help I will really apreciate, 10X.
    My problems, I have some stepper motors with label that says 12v 1A, well, after I checked the DC resistance with my DVOM I have 22ohms on each winding, I am corect that I need 22V/winding + the FET(or bipolar) issue for 1A per motor winding?
    That label is wrong or what??
    Regards Gabriel
    Oct 2005
    328
    Gabriel,
    I am by no means an expert on steppers. In fact I am fighting my own problems trying to implement them in my project. I am an electronics tech by trade, and the threads I saw regarding the load resistors caught my eye.
    That stated, from what I do know about steppers, are the motors you have of a design that they can be used as either bipolar or unipolar? Or are they a "true" bipolar design? How many wires do they have?
    Regards,
    Dave
    Sep 2005
    11
    Well, the motors I have are 8 wire universal stepper motor, and I measured 22ohms on each winding (4 22ohms winding).
    Regards, Gabriel
    Jun 2005
    52
    Quote Originally Posted by Old_Man
    Regards, Gabriel
    Than it looks like the label is for bipolar use with two times two windings parallel. That will give you about 1A at 12V / phase.
    AbSat.
    Oct 2005
    328
    Quote Originally Posted by AbSat
    AbSat.
    Thanks AbSat. That was what I was going to say, but I hadn't had a chance to get back online.
    Good to see that somebody is picking up my slack. :cheers:
    Dave
    Sep 2005
    11
    Thank you, well, I want to use them as unipolar 6 wire, so I asume 22V will be nominal voltage, if I use the 10X voltage rule I need 220V :banana:
    What voltage I should use, just to be safe and fast.
    Regards Gabriel
    1695
    Unfortunately, your motors require too high of a voltage. You won't be able to get much performance out of them with any of the commonly available drives.
    Unless your requirement is very light, it's really a lost cause. Automation direct has "real" motors for $30-$40.
    The same goes for drives. Any that need limiting resistors are good for learning only.
    Jun 2003
    3312
    Whateg01
    Your correct, the only thing I would take exception to is
    "The datasheet says that my FET will have an on drain-source resistance of 1.76ohms(typical)."
    If your using a MOSFET with 1.76 ohms typical on resistance, you need to change them. You should be looking a 40 to 50 milliohm MOSFETS, then the drop is insignificant unless your running huge currents.
    Bipolar transistors do need to be taken into account. However to make more than a rule of thumb drop of .5 to 1.2V depending on current, you would have to measure the actual performance. The comes the issue of getting a high power resistor in that value and wattage.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Oct 2005
    328
    Phil,
    You are right about these FETs having a very high resistance. I used them because of their very good availability. (I had them in my drawer.) I have since changed to a lower impedance FET.
    I am still having problems though with my motors. I can't seem to get enough speed out of them. And I don't think I am getting all of the usable torque out of them.
    Dave
    Jun 2003
    3312
    What ratings are your motors? What is your power supply voltage? I assume you must be using a unipolar setup?
    Oct 2005
    328
    Things not going well
    :frown:
    I have a set of 100 oz.in motors. I am using them in a unipolar configuration. I have been able to spin them, but the max I was able to get was about 500 RPM. And there was almost no torque at that speed. I was able to grab the shaft with my bare fingers and they just started skipping.
    Unfortunately, I haven't gotten a board put together yet to drive 2 coils at once, so I know I may get up to 40% more torque when I do that, but I need more torque and I need about 25% more speed to get the IPM to do job. I will be using this to carry my oxy/acetylene torch, so there won't be much lateral loading, but I need to maintain a decent speed to get a desirable cut.
    The motors are rated for 5.2V 1.4A. These are the seemingly popular HP3 printer motors. I have used an O-scope and a series resistor to adjust my variable p/s to get 1.4A, but I don't remember the voltage I had at the time.
    My setup is a 5' piece of 1/2-13 allthread moving a 8-10 lb carriage on linear bearings using skate bearings. The carriage moves easily with my pinky, so there is little resistance there. Just momentum. I intend to change to 10tpi acme, but this was locally available at 7:30pm and I know that this will decrease the mechanical advantage that the motors have. From what I have read, I will probably get that back in efficiency, though. Actually, I will have to change it because the threads on this piece of allthread are not very good. (when the allthread rotates, the nut wobbles!) I have eliminated the binding by very loosely attaching the nut to the carriage for my x-axis. I can turn the allthread very freely by hand, but the motor can only manage about 4 IPM, or about 50 rpm. I wasn't expecting 500 IPM, but with the success others have had using this motor to drive routers at up to 60 IPM, I figured that with no lateral load, I should have not trouble obtaining similar results.
    Obviously, I need to get more torque. Like I mentioned, I know that I will get more when I drive 2 coils at the same time, but I have my doubts that it will be sufficient, even then. I have read that bipolar motors have more torque. I have also read that motors that can be configured either way (in this case 6-wires) are not capable of that kind of torque. How can I maximize the output from these (or for that matter, any) motors?
    Other than having to synchronize the motors and run them in opposite directions, are there any drawbacks to using two motors per shaft, one at each end? The reason I ask that is because when I get ready to assemble my Y-axis, I will have substantially more mass to move. It seems that I can get 2 smaller motors for much less than 1 bigger motor. I don't mind the added complexity, to a degree. Or do I just have unrealistic expectations from these motors? If these will not work for my application, how big of a motor do I need?
    I appreciate any advice you can give me. I am sure I probably left out some essential detail that would allow you to assist me, but let me know what other information you need and I'll provide it, as well as I can.
    Dave
    BTW, I am hoping to have the parts to build one of the boards on your website. I am kind of thinking of the "discrete" board at http://pminmo.com/discrete/discrete.htm . I intend to do a surface mount board, though, to eliminate all the drilling. I'll send you a copy of the artwork when I do, if that's okay with you.
    Oct 2005
    328
    Phil,
    I was looking at the chopper circuits on your website. They are obviously more complex, but there must be advantages to them. Let me see if I understand them.
    By using a higher voltage you get a quicker rise to the rated current of the motor? Then via PWM you are able to switch on/off that higher voltage to keep the current near the rated current, resulting in current near the rated current for a larger percentage of the pulse. Also, since the current rises to the rated value quicker, at least in theory, the motor should be capable of higher speeds where the pulse width would be shorter?
    Or am I way off base?
    Thanks for your assistance,
    Dave
    Jun 2003
    3312
    Dave,
    Your last post is correct. I really would suggest the L297Uni driver over the discrete driver and going to 40V power supply. 100oz in steppers are not very strong.
    Oct 2005
    328
    Phil,
    Thanks for your input. I certainly appreciate it.
    I may have to relegate these motors to a less demanding project if they aren't strong enough. Do you have any idea how others are getting sufficient torque to drive routers with these motors?
    Dave
    Jun 2003
    3312
    Significantly higher power supply voltage to get your torque and speed. If your not running 30+ volts and both coils, you really havent gotten a good indication of the motor capability yet. If simplicity is part of your construction goal, the SLA7051 board will cost you roughly the same to build.
    Oct 2005
    328
    Decisions, decisions, decisions...
    Phil,
    Thanks. Sorry to be a nag. I really do appreciate your input.
    I guess now I don't know which controller to try. Simplicity isn't really the issue. I'm an electronics tech by trade, so the complexity there isn't much of an issue, but I am somewhat concerned about cost. That was why I thought I would try these motors. The price was right, and if the don't work for this project, I have another in mind.
    You previously mentioned the L297Uni and it looks good, and now you have mentioned the SLA7051. I can see that the SLA7051 is simpler, but which will give me better performance? Is the L297Uni as reliable as the SLA7051? Is the main drawback of the SLA7051 that it is not a chopper circuit? So many decisions...
    BTW, I still intend to use surface mount as much as possible, unless parts availability becomes an issue. I don't know why I want to put myself through the board layout nightmare that sometimes ensues, but anymore thru-hole just seems so antique-ish.
    Thanks again for your input. I am going to have to make you something when I do get this thing going to say thanks. (If you don't give up on me first...)
    Dave
    Jun 2003
    3312
    The 7051 has a chopper circuit built in. As long as your motors are under 2A, and the power supply voltages are the same you will get equavilent performance. If you can find the 7051's there cost is less than the combined cost of the L297 and Fets, and diodes.
    1695
    Dave,
    My motors have about the same rating as yours. I can get about 5000 rpm with a 35v supply when it's unloaded. On my mill with a high friction dovetail cross slide, I get about 30-40 ipm reliably .
    I find that torque is really not the main problem. It's speed. Despite the 110 in-oz torq rating, I cannot stop the rotor from turning by grabbing the 1.25" disk with my fingers, unless I have leather gloves on. My only complaint is that the torque drops too quickly with speed.
    I would recommend a board that can handle as much voltage as possible. I'm going to try 80volts before I look at bigger steppers.
    Oct 2005
    328
    H500 and Phil,
    Thanks for all of your advice and information. It seems I can more easily get the L297 ICs and the associated FETs than I can the 7051. I work for an electronic test equipment mfr. so most parts are pretty cheap . It looks like I will have to use a higher voltage power supply. As mentioned before, I have a good 12V supply, but will have to put together a 35-40V supply. That shouldn't be a problem.
    H500, I am glad to hear that 30-40 ipm is doable. What type of leadscrew are you using? If I can get 45 ipm, I will be happy. I need to get at least that. Also, I am hoping that if I use 2 motors per axis, I can get a little bit more speed. 60 ipm would be closer to ideal. I don't have any real load aside from momentum and friction. For right now, I am planning on using this for an O/A torch. However, if I can use it as a router, with a table change, that'd be great. I guess I'm off to the drawing board to see what I can contrive.
    Thanks again,
    Dave
Page 1 of 3 123
