I would like to know how I can find out the cycle time in back plot mode. I see it in mill 9 but I am not that familiar with X4. any help would be appreciated. thank you
firstly, you must select Backplot operation,then you will find there is a expand menu, click the button, click the info, here is that you need.
When you execute the backplot function, in the dialog box, right under its title bar, is a button with a double arrow. Click on that to expand the dialog. Then there should be a tab that says Info, click on that tab to show the estimated machining time for the operations backplotted. (See attachment.)
