586,075 active members*
3,982 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Ball Screw Vibration
Results 1 to 6 of 6
    Jan 2011
    Hello, need help to see if anyone has encountered this problem before and its possible causes.
    [ame=http://www.youtube.com/watch?v=3BHwotPlyFw&list=UUuqGRDejszix1FmCYlHRFIw& index=1&feature=plcp]L470-1250 - YouTube[/ame]
    The noise is the ball screw for Z-axis vibrating. The motor is not rocking the ball screw back and forth that is visible.
    I want to disconnect the coupling but want to have as much info before I do that.
    Feb 2007
    664
    sounds like the drive is out of balance
    Jan 2011
    Quote Originally Posted by holbieone View Post
    If out of balance how do you correct this?
    Feb 2007
    664
    fist you will need to know if you have digital drives.
    if you do there should be options in the software for tuning the drives
    if not you will need to get the specs on tuning your drives
    on an analog drive there's pot you can adjust one will be a balance pot (sets the voltage the same for both directions )
    Jan 2011
    I found a previous post which describes problem I am having. I am trying to understand what he is talking about here.
    "http://www.cnczone.com/forums/okuma/136703-okuma_ma_axis_vibration.html"
    Problem: z-axis vibrates with slow movement .
    Most worst vibration when pulsehandle is used or rapid at 10%
    If actual position (wanted) is for example 300.486 and if you look actual (APA) coordinates, they vary from 300.48-300.54-> So machine never reaches "goal". No help of changing parameters.
    In Fanuc and Siemens we have sometimes triggered servo (GAIN). But now problem was measuring rod.I think Okuma uses both pulsecoder and measuring rod(?)
    We did take measuring rod wires off and no problem after that. Of course machine accuracy is not as good,but enough for us.
    Z-axis measuring rod change is BIG job, because you have to take loads of parts to get access to rod.
    Feb 2007
    664
    They're talking about disconecting the axis scale , a bad or dirty scale can cause the same problem
    You will need to rule out one thing at a time
  1. pulley causing vibration on feed screw?
    By KPNO in forum Linear and Rotary Motion
    Last Post: 05-25-2011, 05:50 PM
  2. Screw vibration and chatter
    By tfrisbie in forum Want To Buy...Need help!
    Last Post: 01-05-2009, 05:05 AM
  3. Annoying ACme screw vibration
    By EL34 in forum DIY CNC Router Table Machines
    Last Post: 02-10-2008, 02:09 PM
  4. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  5. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
