586,308 active members*
3,837 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Multiple identical parts
Results 1 to 7 of 7
    Mar 2009
    10
    Hello, im trying to machine two identical parts, 2 vices one on each vice. I've been playing with the transform toolpaths. Is it possible to get every tool to do all its operations on one part then move to the next one, instead of doing one operation on one part then to the other part while transforming all the toolpaths at once??? Thank You!!!
    Dec 2011
    Quote Originally Posted by nakaroto24 View Post
    think you need a post that is made to do this.
    Jun 2009
    65
    Yes it's possible! Group NCI Output by: Operation Order
    Mar 2009
    10
    Quote Originally Posted by Rstewart View Post
    That will work if i add a transform toolpaths to every tool but i will end up with too many transform operations.
    Dec 2008
    717
    How many tools are you using? (who cares if there are a ton of transform toolpaths...if you get the program you want...?)
    Although - I think it would be nice to have more options (especially the one you are asking for) in the transform toolpath page...but it works...
    Tim
    Mar 2009
    10
    Quote Originally Posted by WallyL7 View Post
    I usually use 10+ tools on every job. Its becoming very time consuming selecting the right operations for every tool. Plus it would save some travel time on the machine.
    Dec 2008
    717
    10 tools is nothing. The thing I like about the transform toolpath is you can completely custom tailor where the machine goes with each tool regarding travel time per tool. Add it within a tools operations, or add it at the end of all of its operations...etc.
    Is this a huge production run? If it is, the small amount of extra computer time will be saved exponentially at the machine.
    Tim
  1. Turning Multiple Similar but not Identical parts
    By mr chris in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-18-2010, 06:32 PM
  2. how to get multiple parts from a bar
    By firekoe in forum Fanuc
    Last Post: 02-11-2010, 03:23 PM
  3. Multiple parts in one set up...?
    By Rot Iron Racer in forum Dolphin CAD/CAM
    Last Post: 08-16-2008, 05:28 AM
  4. Multiple Parts In M.C.
    By stang5197 in forum Mastercam
    Last Post: 03-12-2007, 01:13 AM
  5. Multiple Parts
    By nitemare in forum G-Code Programing
    Last Post: 12-22-2005, 02:14 AM
