586,072 active members*
4,574 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Toolgrinding / Toolgrinding Machines > what do you use to cut off carbide drill bits and carbide endmills
Results 1 to 9 of 9
    Feb 2012
    Would like to avoid using an abrasive type of cut off wheel due to the mess.Anyone use a band saw or a cold saw or whatever?thanks
    Oct 2011
    carbide
    we use an abrasive wheel on a chop saw
    Jan 2006
    2985
    A wet tile saw might work and keep the dust down.
    Matt
    Oct 2008
    2100
    Abrasive cut off disc.
    Bob La Londe
    http://www.YumaBassMan.com
    Feb 2012
    any surface grinder or pedestal grinder?
    Nov 2004
    260
    When I need to reduce a carbide shaft, I grind a kerf around the circumference.
    About 90 degree kerf aproximatly 20 percent of the diameter deep.
    Then position then kerf cut shaft in a vice with the edge of the keft just on the edge of the vice jaw, tighten vice and strike the extruding shaft with a Hammer.
    It will break on the kerf.
    The better it is supported in the vice the cleaner the break will be.
    For best results match the radius of the shaft in the Jaws to get more contact area.
    If needed clean up the end on a grinder.
    Jan 2007
    210
    OMG,
    .035-.060 wide diamond cutoff wheel, lots of coolant, and 15 seconds on a surface grinder. It doesn't get much easier than this.
    All of the above methods make me shudder and wonder if the posters understand micro-cracking in carbide tooling. The wet tile saw is the best guess here. (Very wet)
    I don't mean to be a jackass but if cutting it is difficult what the heck are you going to do to put on a new end?
    Bob
    You can always spot the pioneers -- They're the ones with the arrows in their backs.
    Aug 2007
    339
    Some carbide tools do come with too long of a shank and need to be shortened or you wear out just the first 1/4 in. and need it retipped.
    CarbideBob about sums it up and is how I would do it and am set-up to do it cause that's how we do it. When I cut them off I have a motorized 3 jaw chuck I put them in and use a .035 cutting disk (for carbide) and plenty of coolent in a spray bottle and hand feed it. This will not destroy your tool and you can resharpen and re-tip the end. Because many of our tools cost over $100.00 this saves a lot of cash.
    We all live in Tents! Some live in content others live in discontent.
    Feb 2012
    I sharpen drill bits (carbide and hss) with a 4axis cnc sharpener and a sharpener that uses coolant when grinding. I was just looking for suggestions. I have been looking for a surface grinder. I also thought that would be a good way to go. Thanks
  1. Carbide endmills on plywood
    By Lionclaw in forum WoodWorking Topics
    Last Post: 07-03-2013, 12:38 PM
  2. Carbide Drill Bits and End Mill Coupon Code
    By jtg1969 in forum News Announcements
    Last Post: 07-18-2011, 03:18 PM
  3. 1.00" Carbide endmills for plastics ???
    By MauserBob in forum Want To Buy...Need help!
    Last Post: 04-30-2009, 07:16 PM
  4. Chatter with Carbide Endmills
    By smittys800 in forum Haas Mills
    Last Post: 12-27-2007, 02:41 AM
