Job pending delivery - Thank you for all of your expedient quotes
RFQ
I need a single spacer machined from steel. I haven't been able to find an off the shelf component with these specs. I don't have the means to grind a washer to these specs but perhaps you do?
This is a teeny tiny job. I'd like a reasonably tiny quote.
Part: Spacer
Quantity: 1
Material: Steel
However you would like to machine this is up to you.
Specs:
.694 OD
.540 ID
.036 thickness
Tollerances:
OD +/-.01 max
ID +.01 max
thickness +.01 max
solidworks 2011 files available on request
